Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 22nd of October 2006 (Sun)   #1
extrememc
Default Camera Historgram vs. Adobe Bridge Camera Raw
I took some test picture and view them in my historgram and it didn't
show highlights blow out, so I open it up in Adobe and it showed some
blown highlights that the camera didn't reveal. Could there be
something wrong with the camera?
Photography is an expression of the mind!!!!!!!!!!!!!
Canon Rebel XT/ 30D
http://www.photography-on-the.net/fo...&postcount=373
extrememc is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #2
Di-MC
Di-MC's Avatar
Smile Re: Camera Historgram vs. Adobe Bridge Camera Raw
Camera histogram is hardware based and does a pretty good analysis to help you decide whether you should adjust the exposure and take a new shot. Adobe histogram includes much more complex algorithm and could certainly pick-up more due to its sensitivity. Unless they are worlds apart (which I would doubt) I wouldn't worry too much.
Canon EOS 5D, PowerShot A540
24-105 F4L IS USM, 70-200 F2.8L IS USM
50mm 1.8 II, EF 12 II Extender, 580EX
Di-MC is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #3
mizuno
User is banned from forums
Default Re: Camera Historgram vs. Adobe Bridge Camera Raw
Adobe Bridge sometimes applies some some default RAW conversion settings, perhaps this was the case.
mizuno is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #4
ofdphoto
"stupidly long verbal diarrhoea"
ofdphoto's Avatar
Yep the Adobe blowout will depend on the settings picked in the RAW converter.
ofdphoto is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #5
malla1962
malla1962's Avatar
The in camera historgram is based on that little jpeg you look at in the viewfinder.
malla1962 is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #6
Glenn NK
Glenn NK's Avatar
I've observed something that may or may not be related to the OP's question, and I would welcome some comments from others:
Using the histogram in DPP, I've taken a number of shots wherein the histogram is clipped (at the top). Under "White balance adjustment", every shot defaults to "Shot settings".
Then if the DPP "White balance adjustment" is changed to "Daylight" (for example, or any other setting), quite often the histogram is not clipped at any point, and the shape of the histogram curve is completely changed - with peaks at different locations. This effect is much more pronounced (or so it seems) when the original shot has some considerable portion in the shade or dark areas.
All files are RAW, and the WB settings were AWB.
Glenn NK
Glenn NK is offline   Reply With Quote
Old 22nd of October 2006 (Sun)   #7
Quad
Quad's Avatar
Glenn NK
The clipping does not occur at the top. The histogram (in terms of clipping) is only too far right or left indicating lost shadow or highlight information. It may go right up to the top or past that is only a pixel count of how many pixels are at that brightness location. If you change white balance then there will be a redistribution of some of the colours and so the pixel count at one location will change. You will see this better if you change to looking at a RGB histogram.
Likely the OP found linarms' and mizuno's comments relevant.
Quad is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Adobe Camera RAW 4.1 is Available Here tjloeb RAW, Post Processing and Printing 5 1st of June 2007 (Fri) 01:10
Comparison Apple Aperture or Adobe Camera Raw with Bridge offtheroad RAW, Post Processing and Printing 0 19th of February 2007 (Mon) 15:31
Adobe Camera RAW 3.6 Hermeto RAW, Post Processing and Printing 0 6th of December 2006 (Wed) 23:08
Adobe Camera Raw 3.3 out shiato storm RAW, Post Processing and Printing 8 20th of January 2006 (Fri) 08:24
Adobe Camera RAW MattyOh! Canon G-series Digital Cameras 0 25th of February 2003 (Tue) 04:25
