Thread started 22 Oct 2006 (Sunday) 03:20
Lens hood, UV filter and lens cap - all at once?
fi20100
Oct 22, 2006 03:20 |  #1
Lens hood, UV filter and lens cap... can all three be on at for instance the EF 70-200mm L f/4 at once? Or will there be a problem?
And for that lens, would the B+W UV-filter MRC (010M) be a good one?
Stefan
5D, 5D, 40D + 17-40L, 24-70L, 70-200L, 50/1.4, 85/1.8, 100L Macro and some other stuff.
flickr (external link), 5∞px (external link)
mrfourcows
Oct 22, 2006 04:27 |  #2
you could use all at once, the only problem is that you'll get a black picture.
remove the lens cap when shooting!
and the filter is a good choice.
gear | flickr (external link)
Lani ­ Kai
"blissfully unaware"
Oct 22, 2006 04:30 |  #3
What sort of problem are you anticipating?
Anyway, this is perfectly okay. The only exception to this is lenses with hoods that screw into the filter thread, like with certain Sigma lenses (eg 50mm Macro, 105mm Macro). Since the lens cap and hood both occupy the same thread, it is not possible to have both on simultaneously.
B+W MRC filters are excellent.
SmugMug | [URL="http://www.faceb​ook.com/kohei.photo"]F​acebook | [URL="http://twitter.c​om/KoheiNakamura"]Twit​ter | [URL="http://gplus.to/​koheinakamura"]Google+ | [URL="http://500px.com​/KoheiNakamura"]500pxexternal link Equipment list | Colorburnexternal link
Founder, Canon Digital Photographyexternal link group on Facebook
fi20100
Oct 22, 2006 04:33 |  #4
:) Haha, yes of course :) I was just thinking since when I borrowed a 24mm f/2.8 w/ a UV filter, the lens cap seemed to be very loose, and came off in the bag many times. Just wanted to make sure :) Thanks for your reply.
Stefan
fi20100
Oct 22, 2006 04:35 |  #5
Thanks Lani Kai. Since I only have the kit lens at the moment, and would really like to start expanding, I just don’t want any bad surprises :)
Stefan
Carzee
Oct 22, 2006 04:41 |  #6
Firstly, in studio you don't want any of them. Outside IMHO the stupid caps get in the way and take up precious seconds. A UV is the better lens cap. I have to laugh at the little strings holding onto a cap I see dangling from lenses. real tourist look.
Lens hoods I use are the rubber ones -they bend, they collapse and squish into small spaces, they cost little if you lose 'em.
Having a bad day? Feeling down? Bantar Gebang Attitude Enhancement Images (external link)
fi20100
Oct 22, 2006 04:52 |  #7
Actually, I think you’re right. Having a UV filter on at all time, the lens cap will probably only be on the lens when it’s in a bag.
Stefan
SkipD
Joined Dec 2002
Oct 22, 2006 06:33 |  #8
fi20100 wrote in post #2152483 (external link)
You can forget the UV filter under most conditions. The only time that it might make any sense at all to use one is if you are shooting at the beach with blowing sand and/or salty sea spray.
Make sure you always use the lens hood - whenever the lens is on the camera. It will not only provide protection against stray light, but will provide a tremendous amount of physical protection as well. There are many threads in this forum describing this.
Many of my lenses go into the camera case with their hoods in a ready-to-use position. Those with hoods long enough to keep other things in the case from contacting the front element of the lens don't even get a cap put on them when in the case. Those lenses with very wide hoods (such as my 16-35L) get a cap put on them without removing the hood. Those lenses that are too long to go in the case with the hood in a ready-to-use position (such as my 70-200 f/2.8L IS) get the hood mounted in reverse with a cap mounted when stored in the case.
Use proper cleaning procedures for your lenses - the goal of which is to NEVER grind any dirt into the lens - and you will have no problem with scratches. None of my 40-year-old (and well used) lenses have any scratches, and I have never had a filter on any of them except for occasional creative purposes.
Skip Douglas
Lani ­ Kai
Oct 22, 2006 07:47 |  #9
You should remove the hood if you're using flash, though.
SkipD
Joined Dec 2002
Oct 22, 2006 08:17 |  #10
Lani Kai wrote in post #2152960 (external link)
This is true only if one is trying to use the camera's built-in flash. A Speedlite will be high enough to clear any lens hood in the Canon line, and the original poster has a 430EX.
Skip Douglas
jr_senator
Oct 22, 2006 08:39 |  #11
SkipD wrote in post #2152825 (external link)
Damn fine advice, I would just add...don't use the collapsible, rubber hoods. They don't properly protect a lens.
PetKal
Oct 22, 2006 08:47 |  #12
Not likely as long as you:
(1) Take the lens mount cap off before attempting to couple the lens onto your camera body.
(2) Remove the lens dust cup just before depressing the shutter.
Potenza-Walore-Prestigio
Anders ­ Östberg
Joined Nov 2003
Oct 22, 2006 09:05 |  #13
Carzee wrote in post #2152626 (external link)
I would disagree with that, you can get flare indoors just as easily as from the sun, not least in the studio with strobes or strong lights. Use a hood at all times...
Anders Östberg - Mostly Canon gear - My photos (external link)
SkipD
Joined Dec 2002
Oct 22, 2006 09:23 |  #14
jr_senator wrote in post #2153106 (external link)
You are absolutely right about the caution against using the collapsible rubber hoods. I should have included that in my other post. One should only use properly designed (for the particular lens/body combination) rigid lens hoods for the best results.
Most collapsible rubber lens hoods don't provide the proper shielding from stray light and for sure don't provide the same level of mechanical protection from everyday knocking around or crashing to a hard surface.
I can attest to the level of protection that a properly designed rigid (metal in this particular case) hood can provide against a major crash (a 4-foot drop to concrete, lens-first). That happened 38 years ago, and the lens and body are still in good shape without repair work being required. I did replace the hood for aesthetic reasons, though.
Skip Douglas
jr_senator
Oct 22, 2006 12:05 |  #15
SkipD wrote in post #2153248 (external link)
Hay, if one can afford to be vain...
22,971 views & 0 likes for this thread
Latest registered member is livingHi
785 guests, 294 members online
