Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 23rd of October 2006 (Mon)   #1
wgforster
Default Speed of Focusing Points
My question stems from shooting gymnastics with a 1D2, primarily with a 85/1.8. It seems like my Auto Focus has trouble focusing fast enough for the moving action but without getting into a gymnastics thread, does anyone know if there is a difference in the focusing speed of off-center focusing points. There is one mention in the manual that "if focus can not be achieved with the AF-assist light of a Speedlite select the center AF point. An off-center AF point may not be able to achieve focus." This implies that the center AF point provides some benefit that the off-center points don't. Any ideas?
Thanks,
Bill F.
wgforster is offline   Reply With Quote
Old 23rd of October 2006 (Mon)   #2
RgB
RgB's Avatar
Default Re: Speed of Focusing Points
Apparently the centre has higher precision AF.
But someone else perhaps can get a bit more technical than me
Daniel Speranza
30D - 580EX II
Lee ND Grad Filters---77mmWide Angle Adapter
10-22mm f/3.5-4.5 USM --- 24-70mm f/2.8L USM
Website * Flickr * Gear
RgB is offline   Reply With Quote
Old 23rd of October 2006 (Mon)   #3
Hermeto
Hermeto's Avatar
Pretty much everything on that subject is explained HERE.
Welcome to POTN!
Hermeto is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
which is the focusing points that u don't use? mantra Canon EOS Digital Cameras 58 17th of January 2007 (Wed) 11:15
Focusing to Pin Points on the S3... chicagoastronomer Small Compact Digitals by Canon 4 22nd of December 2006 (Fri) 17:18
Focusing problems using different focus points shniks Canon EOS Digital Cameras 10 8th of January 2006 (Sun) 18:47
Canon MarkIIN Focusing Points? @tort Canon EOS Digital Cameras 6 6th of December 2005 (Tue) 20:25
drebel focusing points bballboy30 Canon EOS Digital Cameras 6 26th of January 2005 (Wed) 19:37
