Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 27th of October 2006 (Fri)   #1
g_robins
g_robins's Avatar
Default Selecting AF point
I have a 350D and use it mostly for rallying. My question is this , is it better to have the AF point set to auto or would it be better to use the centre focus point. I do use it in AI SERVO mode as well.
Canon1D Mk.IIN Canon 1D MkIII, Canon 70-200mm f/2.8L IS, Sigma 24-70mm f2.8,Sigma 10-20mm, Canon 580 EX Flash,Yongnuo 565 Flash, Lowepro Magnum AW, Lowepro belt system.
Have a look at www.grahamrobins.net
g_robins is offline   Reply With Quote
Old 27th of October 2006 (Fri)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: Selecting AF point
I prefer to set my AF point myself. Don't know if the 350D has it, but the 20D and 5D have a mini-joystick that I've set to let me shift active focus point on the fly.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 27th of October 2006 (Fri)   #3
Mark_Cohran
Moderator
Mark_Cohran's Avatar
Take control of your camera and manually select the focus point so that you control where the focus will be. That's my opinion. I don't exclusively use the center focus point, though it would be good for a beginner to start that way. I choose the AF point that is closest to where I want to focus for the given composition, then I recompose as required (which is usually much less of a recomposition) than if I used the center point.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Thirty-five years of shooting and still learning.
My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW)
G&N FORUM EARLY ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 27th of October 2006 (Fri)   #4
g_robins
g_robins's Avatar
Thanks guys for the input but let me explain. When I am takeing photos on a rally I track the car with the AI Servo and then when the car fills the frame or is at the point I want the photo I then fully press the shutter. So centre point AF would seem to be the correct setting or do you have any other views.
Old 27th of October 2006 (Fri)   #5
syntrix
syntrix's Avatar
Seems right to me. If you are in auto, and start panning with the shutter button 1/2 pressed, are you committed to the camera's chosen af points?
I would rather have the control.
moew!!!!!
syntrix is offline   Reply With Quote
Old 27th of October 2006 (Fri)   #6
Kennymc
Kennymc's Avatar
If you track with the centre focus point in A1 servo with the shuter half pressed it will keep on refocusing until the button is pressed fully... As long as part of the subject is covered by this AF point all should be well...
Kennymc is offline   Reply With Quote
Old 27th of October 2006 (Fri)   #7
peacock
peacock's Avatar
Hi Graham , i think most people preffer to select their AF points rather than leave it to the camera, KennyG wrote a piece with some info on using AF points .
http://photography-on-the.net/forum/...af+motorsports
Just started populating a site with snaps @
www.3cakes.co.uk
peacock is offline   Reply With Quote
Old 27th of October 2006 (Fri)   #8
g_robins
g_robins's Avatar
Hi John, thanks for that, I am of to Minehead in the morning (4am). Hope to get loads of lovely gravel rally photos.
Old 27th of October 2006 (Fri)   #9
peacock
peacock's Avatar
enjoy the trip , look forward to seeing what you get
www.3cakes.co.uk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Point/Counter-Point: kids baptism ginger55 People 5 14th of March 2006 (Tue) 16:16
Quick fix or painstaking point by point clean up? wu_wei0 RAW, Post Processing and Printing 3 8th of January 2006 (Sun) 13:39
selecting the AF Point pacific General Photography Talk 8 6th of December 2005 (Tue) 03:48
Selecting the AF Point pacific General Photography Talk 14 2nd of December 2005 (Fri) 09:50
Selecting a Focus point (350D) LastLine Canon EOS Digital Cameras 9 27th of July 2005 (Wed) 04:11
