Thread started 30 Oct 2006 (Monday) 14:13
Focus variations
curiousgeorge
Joined Feb 2006
Oct 30, 2006 14:13 |  #1
Have anyone noticed how, when you autofocus on a particular point in the frame, if you repeatedly press the shutter button half way, the focus will jump around ever so slightly backwards and forwards? Even if you keep the camera still.
The lens is therefore unsure as to the distance to focus on and it follows that the image is unlikely to be correclty focused.
This may explain how, when I take two shots of the same image, one is better focused than the other.
Photos from Iceland (external link) | London (external link)
Canon EOS 6D | Canon 24-70mm f/4L | Samyang 14mm f/2.8 | Canon 70-200mm f/4L | Speedlite 430EX II | Canon Powershot G9
Jon
Joined Jun 2004
Oct 30, 2006 14:17 |  #2
Remember, the AF sensor area's actually somewhat larger than the area delimited on your screen. It's quite possible for the AF point you use at any given time to be picking up something outside the area you were expecting. AlsoAF isn't designed to nail the exact same spot every time; it's considered within spec if it's within somthinge like 1/3 the DoF when focussed.
Jon
Cocker Spaniels
curiousgeorge
Joined Feb 2006
Oct 30, 2006 14:37 |  #3
It happens when the entire frame is in the same focal plane though, eg the cover of a book.
I wouldn't expect it to vary at all in this situation.
gasrocks
Oct 30, 2006 14:39 |  #4
Are you swaying back and forth?
philbyuk
Gallery: 52 photos
Joined Nov 2005
Oct 30, 2006 14:43 |  #5
maybe its just rechecking the focus !!!
My 365 '2018' (external link)
Jon
Joined Jun 2004
Oct 30, 2006 14:52 |  #6
curiousgeorge wrote in post #2191361 (external link)
Read point 2 of my post. Also, your subject needs to be sufficiently high contrast for it to get a good read. The lower the contrast, the more likely you'll have variations. Also the smaller the aperture.
Jon
Cocker Spaniels
curiousgeorge
Joined Feb 2006
Oct 30, 2006 16:15 as a reply to  @ Jon's post |  #7
OK, so it's normal behaviour, but in real life shots this happens every time and it's frustrating when you don't know when it has the best focus reading.
I thought someone else would have noticed it.
I would use MF if I could rely on my eyesight.
1,353 views & 0 likes for this thread
Focus variations
Latest registered member is simon milton
672 guests, 367 members online
