Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 30th of October 2006 (Mon)   #1
coreypolis
User is banned from forums
coreypolis's Avatar
Default EDU: Using Studio Gels
I get asked about thisfrom time to time, so I thaught I would share.
One of the cheapest and easiest ways to change the background of an image is a studio environment is to add gels to the lights. Getting the desired result is the hard part.
You can use any color seamless. White is one of the easiest to work with, but requires some knowledge of proper exposure. Gray and black are other popular choices.
The first thing is to try and have the background light on a separate power system, so that you can control it independently. You also need to make sure that the key light and or fill light doesn't contaminate the background. Any white light will change the color of the background light. Using black flags and aiming the lights is key. You also want the subject as close to the key light and as far from the background light as possible.
Instead of buying every gel under the sun, you can change the color by adjusting the intensity of the background light. For the following test, we took a gel (labeled to the left), used a light meter to measure the incident light on the seamless paper, and adjusted the location of the lights to obtain a normally exposed image at f/8. We did this because it is in the middle of a 9 stop range (We used a 135mm L F/2 from Canon, one of the few lenses to have this large of a range) instead of using another lens and having to adjust the light intensity for the extreme values. This allowed us to change the exposure in 4 stops in either direction. The example shows a range from f/2 at +4 stops of light to f/32 at -4 stops of light.
We took the gel, cut it in 2, and used laundry pins to attach it. DO NOT let it touch the actual bulb, it will melt it, and white light will go through and ruin the shot/lose intensity in the color.
Cliff notes:
Adjust the intensity of the light changes the color.
The results can be seen below.
coreypolis is offline   Reply With Quote
Old 30th of October 2006 (Mon)   #2
Wilt
Wilt's Avatar
Default Re: EDU: Using Studio Gels
Great illustration of a single gel creating many different tonal renditions of the same fundament color. Your shot also illustrates why one needs to separate the model from the background, because of the color cast onto her skin and hair by the light bouncing from the background.
I might also suggest that a series of shots of gray background paper with differing levels of light falling on the paper can alter its tonal rendition from black to white!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 31st of October 2006 (Tue)   #3
nanko
where did you get the gel material? what is it?
Canon Digital Rebel XT, EF 50mm f/1.4 USM, EF 17-40mm f/4L USM, EF 100mm f/2.8 Macro USM
Aikiphoto-Yake 3 strobes powerful 510w/s strobes lighting kit
Sekonic L-358 Flashmeter,
LowePro CompuTrekker AW
nanko is offline   Reply With Quote
Old 31st of October 2006 (Tue)   #4
coreypolis
coreypolis's Avatar
this was a Lee gel, and is available at most pro photo/video stores.
Old 21st of December 2006 (Thu)   #5
akhoopes
akhoopes's Avatar
are you using a steady light for this gel or a flash, and if you are using a steady light, how many watss does it have to be to show up on the camera, ive tried 250 watts steady and nothing, but my ab800 flash it shows up but i cant get it quite right at all
BILL HOOPES www.jumpingthrewphoto.com
40D, Sigma 17-70, 50mm F1.4, Newton Bracket, 580ex
akhoopes is offline   Reply With Quote
Old 22nd of December 2006 (Fri)   #6
Benji
Using a gel on a white background will give you highlights in the hair like the OP has shown. If your client doesn't mind having blue, green. red or orange hair this is great, but if they would like to have their real hair color use a low key background. My tutorial on using gels can be found here http://www.photocamel.com/index.php/topic,15518.0.html
Benji
Benji is offline   Reply With Quote
Old 11th of January 2009 (Sun)   #7
Blackey Cole
There was a link to a you tube video that showed and English photographer demonstrating how to light a subject and a big part of it was on using gels to get different effects from a neutral background also flooding it with light for a white bg and blocking light from it for a black bg.
I lost my link and was wondering if someone could post it so I can go review these videos. I believe it was a series of three or more you tube videos.
Blackey Cole is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
More messing around with gels Jay McLaughlin People 12 19th of June 2007 (Tue) 17:05
Gels, looking for info samd12 Small Flash and Studio Lighting 2 20th of April 2007 (Fri) 17:22
Help with gels teeny General Photography Talk 7 10th of March 2007 (Sat) 19:19
First time using gels Stackinchips People 5 28th of February 2007 (Wed) 00:53
gels? kyle General Photography Talk 1 28th of April 2005 (Thu) 21:42
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
