#1 |
I am looking at trying to create a studio. I am relatively new to photography and have mostly done landscape type of shooting. I am a recently graduated, but unemployed college student, so I am trying to do what I can on a budget. Anyway, I found some cheap ($9.99) work lights on sale at Sears (Craftsman 500 Watt Tripod Light with Portable Stand ). I was just wondering if these might be okay to get me started before I have enough money to invest in better lighting. Thanks
F. Lumpkin |
| sponsored links |
#2 |
They also have a 1000Watt Tripod available for a little more. What do you think?
F. Lumpkin |
#3 |
They would work - maybe bounce the light off a white wall/ceiling - and use a custom WB setting, but just be careful how close you get to them, they'll get EXTREMELY HOT! (not very comfortable for any model!)
There are some threads on POTN that feature this type of lighting - sorry but I haven't time now, but use the search facility and see if you can find them.
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea |
| sponsored links |
#4 | |
While I understand that continuous lighting can be very effective, and far easier to see in respect of shadows, the main issue as I understand is heat. High wattage bulbs produce colossal heat. The outer casing on the 500w lamp will be too hot to touch within minutes and the light produced will wilt flowers and melt plastic objects if left in the line of fire after a very short period. Also, it might be difficult to control the strength of the light - although moving it back wards or bouncing the light around will perhaps get around this. Inspired by the Strobist site I have elected to use multiple flash guns on radio releases. The releases are now cheaper than PC leads on fleaBay and old,second hand or cheap simple flash guns can then be deployed in single or multiple set ups. I've only just started, so much of the above is just speculation or with reference to the comments of others far more qualified than myself. It may give you some food for thought though.
John Sims Canon 60D, 30D, 10D, AE1 & some other stuff Last edited by John Sims : 31st of October 2006 (Tue) at 04:23. Reason: I can't write proper ;-) |
#5 |
you also need ALOT of continuous light to equate to the shutter speeds a flash can give you. Curtis N has a sticky on this i believe. Look through the stickys on the flash main page.
continuous lights are alot easier to work with for setting up an image, and can be alot more forgiving to a beginner. just know the downsides. nice thing about sears is you can return it if you dont like it after a couple days. Buy it and try it.
350d, 5d, 17-40L, 28-70L, 135L, 70-200L, 430EX,
Sigma 150mm macro - full alienbees studio set. |
#6 | |
Master Flasher
Almost any kind of light can be used for shooting inanimate objects. For shooting people, continuous lighting only works for extremely cooperative subjects with a fair amount of heat tolerance. There are very good reasons why studio photographers use strobes.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#7 |
I'd say go for it. Just install a couple of tanning beds for use during down time.
#8 |
Moderator
Look here for some ideas: ** IMPORTANT LINKS: Studio Lighting **"
FrankC - 20D, RAW, Manual everything... Classic Carz, Racing, Air Show, Flowers. www.FrankCizek.com Find the light... A few Car Lighting Tips, and MOVE YOUR FEET! Have you thought about making your own book? // Need an exposure crutch? |
| Thread Tools | |
| Display Modes | |
| Where can i find inexpensive....... | Tumbler | The POTN Lounge | 2 | 17th of June 2007 (Sun) 00:52 |
| Idea for inexpensive lighting | RRitch | Small Flash and Studio Lighting | 14 | 18th of November 2006 (Sat) 08:55 |
| Coin Lighting - a few alternative ways to do it. | PhotosGuy | Small Flash and Studio Lighting | 5 | 11th of April 2005 (Mon) 21:41 |
| inexpensive lighting solution | perfectpixel | Small Flash and Studio Lighting | 6 | 22nd of December 2004 (Wed) 06:01 |
