Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 31st of October 2006 (Tue)   #1
srv656s
Default Help me improve my bear shot from Alaska. (PIC)
I took this a month ago in Alaska. It's probably the best of my series I took when this bear came by. I really like the photo, but something just doesn't seem quite right with it. I've tried tweaking it a few times, but have not been happy with the results.
The lens I used had some bluriness in some areas, and I think the color isn't quite right with this one either. I'm open to any and all suggestions.
If you have any ideas on how to improve this image with any post processing techniques, I would love to hear from you. Also, if you wanted to play with it yourself, feel free.
PIC:
Original:
http://ct.pbase.com/o5/30/722230/1/6...1.IMG_6229.jpg
Don't know why this isn't working... here's a direct link to the gallery-
Link to gallery:
Link - Alaska pic
srv656s is offline   Reply With Quote
Old 31st of October 2006 (Tue)   #2
Scottes
Trigger Man - POTN Retired
Scottes's Avatar
Default Re: Help me improve my bear shot from Alaska. (PIC)
Link broken.
Forbidden
You don't have permission to access /o5/30/722230/1/69488198.4k04f3rI.IMG_6229.jpg on this server.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info
Finally, I have a Gallery!
Follower of Fidget - Joined the cult of HAMSTTR
Scottes is offline   Reply With Quote
Old 31st of October 2006 (Tue)   #3
srv656s
I think i fixed it...
Shawn
Old 31st of October 2006 (Tue)   #4
Akchas
Akchas's Avatar
Shawn
I am not sure if you were talking about the link or the image?
It needs three things I can see the nosie need to be cleaned up, a un-sharpening needs to be done, and last it needs the colors corrected.
Nice to see another Alaskan Photographer here.
Chas
To achieve great things, first dream great dreams!
Akchas is offline   Reply With Quote
Old 31st of October 2006 (Tue)   #5
srv656s
Akchas-
Just fixed the link, not the picture.
thanks for the feedback-
Shawn
Old 31st of October 2006 (Tue)   #6
lostdoggy
King Duffus
lostdoggy's Avatar
I could try to fix it but just can't post it for you to see. You don't EDIT OK listed in your profile.
lostdoggy is offline   Reply With Quote
Old 31st of October 2006 (Tue)   #7
lostdoggy
King Duffus
lostdoggy's Avatar
Your top 2 links are forbidden again
Old 31st of October 2006 (Tue)   #8
srv656s
I edited my prefs... didn't know that option was even in there!
Old 31st of October 2006 (Tue)   #9
srv656s
I don't know why that's such a problem. It looks like the direct link is still working...
Shawn
Old 1st of November 2006 (Wed)   #10
Chazs
I like the photo. A little cropping helps. Also, some photos may just not bode well for print, and are better suited for the web....and just like people, some photos benefit more from a little spicing up (borders, shadows, etc) (aka, makeup). I still like the photo a lot, even though it may not make a perfect print.
Chazs is offline   Reply With Quote
Old 1st of November 2006 (Wed)   #11
pxl8
pxl8's Avatar
Here's my effort, the steps were:
Noise ninja using ISO800 profile
Set colour balance from the water foam
Tweaked levels
Ran focus magic to recover some sharpness
Cropped
USM with a 50px radius, 15 strength to increase local contrast
Duplicated the layer
Mono conversion
Created a mask for this layer from luminance values
Set top layer to Soft Light blend mode
Reduced layer opacity to 70%
Scaled to 800px wide
Ran focus magic again, 1px size, 50% strength
-- PXL8
1DmkIII, 40D + 135mm f/2L, 24-105mm f/4L, 200mm f/2.8L, EF 50mm f/1.4
pxl8 is offline   Reply With Quote
Old 1st of November 2006 (Wed)   #12
lostdoggy
King Duffus
lostdoggy's Avatar
Wow Pxl8 thats great work, now I'm too embrass to post mine!!!
Old 1st of November 2006 (Wed)   #13
StewartR
"your nose is too big"
StewartR's Avatar
grandad35, I think you need to calibrate your monitor. The colours in the effort you posted are all over the place.
StewartR is offline   Reply With Quote
Old 3rd of November 2006 (Fri)   #14
srv656s
Wow, I agree. I really like the way that turned out... thanks for messing with that. If you have that in the original size, I'd love it if you could send it to me...
Thanks for the help!
Shawn
Old 3rd of November 2006 (Fri)   #15
TeeJay
TeeJay's Avatar
Nice pic, and some fabulous work done by others, however, each of the other posters (IMHO) have made the same mistake(?) - in that the positioning of the bear makes it appear to be LEAVING the frame, I think it would look better if it had room to move into (i.e. more room to the left, as we look at it)
Maybe the only way to overcome this is to crop close, but in a panarama view.
TJ
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea
TeeJay is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Halo Bay Alaska Spring Bear Cubs Blue Deuce Wildlife 17 21st of July 2007 (Sat) 15:33
How can I improve this pic of my cat? colle Critique Corner 24 15th of July 2006 (Sat) 21:17
Manns Chinese Theatre: can anyone improve this pic? PAFC2004 Urban Life & Travel 4 1st of June 2006 (Thu) 02:19
Bear Photography in Alaska - Where? picworx Wildlife 1 14th of April 2006 (Fri) 23:19
How to improve the pic in this situation? stranger Canon G-series Digital Cameras 2 27th of August 2003 (Wed) 11:38
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
