Thread started 04 Nov 2006 (Saturday) 16:23
Can someone please explain what exactly TTL, E-TTL and E-TTL II mean?
TMR ­ Design
Joined Feb 2006
Nov 04, 2006 16:23 |  #1
I know this is a really basic question but I never really see this explained so whenever I see one of these abbreviations being used I am not sure what the distinction is between them.
Can someone give me the rundown?
Robert
PeaPicker
in the twilight zone
Nov 04, 2006 16:28 |  #2
Check out this link.
Look down in table of contents. :)
http://photonotes.org/​articles/eos-flash/ (external link)
Jon / 40D / Pics (external link)
Curtis ­ N
Master Flasher
Nov 04, 2006 16:54 |  #3
TTL is an abbreviation for "through the lens". In a nutshell, TTL flash metering is a concept used by many camera manufacturers with film, measuring light reflecting off the film and shutting off the flash "in real time" as the exposure occured. A different system was required for digital cameras, and Canon refers to its version as E-TTL. Enhancements were made a few years ago and the enhanced version they call E-TTL II. E-TTL in its various forms uses a preflash to calculate the necessary flash power required before the shot is taken.
I highly recommend reading the link PeaPicker provided. It's a bit long, but very enlightening if you want to understand Canon's flash systems.
TMR ­ Design
Joined Feb 2006
Nov 04, 2006 19:18 |  #4
PeaPicker wrote in post #2216612 (external link)
Thanks Jon,
I just read a majority of that link. It helped quite a bit.
Robert
PeaPicker
Nov 05, 2006 10:59 |  #5
TMR Design wrote in post #2217197 (external link)
Thanks Jon,
Right before I noticed your post I just happened to enter "flash photography" on "The Google" and this site came up.
I learn something new here everyday.
Remembering it is the problem.
DavidEB
Nov 06, 2006 09:45 |  #6
E-TTL is a variant of ETTR.
ETTR means Expose To The Right, and is a method of using the histogram to get correctly exposed shots. The right side of the histogram represents the brighter pixels -- by exposing to the right, you get a nice, bright image.
E-TTL means Expose To The Left, and is canon's patented flash system designed to produce left-shifted histograms, giving underexposed flash shots.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
Curtis ­ N
Master Flasher
Nov 06, 2006 09:52 |  #7
DavidEB wrote in post #2224249 (external link)
That explains a lot!
:rolleyes:
RuggerJoe
Nov 06, 2006 10:27 |  #8
Heheh...Never thought of it that way. :lol:
Joe
Comments / critiques always welcome.
http://www.flickr.com/​photos/ruggerjoe/ (external link)
Canon 350D
EF-S 17-85 IS USM | EF 50 1.8 | EF 70-300 IS | 580EX | a couple of kit lenses
All of which are all better than my skills.
scottbergerphoto
Joined Jun 2003
Nov 06, 2006 13:35 as a reply to  @ RuggerJoe's post |  #9
http://photography-on-the.net …?t=46311&highli​ght=ettlii
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
DavidEB
Nov 06, 2006 13:46 |  #10
Scott, welcome back, haven't heard from you in a long time. you've always been really helpful, especially on the topic of flash.
David
scottbergerphoto
Joined Jun 2003
Nov 07, 2006 13:43 as a reply to  @ DavidEB's post |  #11
Thanks. I even got a new trench coat.;)
Best Regards,
Scott
Titus213
Nov 07, 2006 17:07 |  #12
scottbergerphoto wrote in post #2230294 (external link)
OK, zip it up and get on with business......:o:lol:
Dave
Perspiring photographer.
Titus213
Nov 07, 2006 17:15 |  #13
While this is a clever (and often accurate) description of the acronym the actual description is Evaluative Thru The Lens. The II added recently denotes a new version that in its mystery is probably darker than David's explanation above.
Evaluative - that pre-flash that is quite often not seen - is used to evaluate the scene.
TTL - it's done thru the lens by the camera as opposed to on the flash.
Dave
totalbeginner
Feb 05, 2007 05:43 as a reply to  @ Titus213's post |  #14
I've always been very frustrated by flash photography, but thanks to this thread it's actually starting to make sense! It really does make a difference when you know how your camera is thinking and I've actually managed to capture my first shot using fill flash. I know it's not great, but it's a start!
The only thing that I'm still unsure about is colour temperature. If you're using fill flash then you have a mixture of colour temps, what should you use as the white balance? Or, is it best to sort it out when you process your raw file?
View my gear list HERE
Don't submit to stupid rules, be yourself and not a fool. Don't accept average habits, open your heart and PUSH THE LIMITS!
René ­ Damkot
Feb 05, 2007 07:20 |  #15
Set the WB to the ambient color temp, and match up the flash by using a color gel.
Matching up mixed lighting in post is nearly impossible.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
47,883 views & 0 likes for this thread
Latest registered member is thisisntme
747 guests, 405 members online
