Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 10th of November 2006 (Fri)   #1
beanster
Default Photos of plasma screen
Why oh why when i take a picture of my plasma does the image of the screen look covered in an oil slick.
My canon a95 could do it fine but not my canon 30d. wierd.
Any explanations more than welcome because I have no idea and it's bugging me.
Matt
Canon 5D Mark II : Canon 30D : Canon 50mm f1.4 : Canon 17-40mm f4L : Canon 24-70mm f2.8L : Canon 70-200mm f4L : Canon 100mm f2.8 Macro : Canon 135mm f2L : Canon 85mm f1.8 : Canon 430ex : Manfrotto 055ProB + 488RC2
beanster is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #2
munchy
Default Re: Photos of plasma screen
example? Let's see!
munchy is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #3
beanster
I'll post a shot up when i get home, i'm at work at the mo (hey it's a slow friday ).
Matt
Old 10th of November 2006 (Fri)   #4
KCMO Al
I don't know about plasma or computer screens, but I know to take a photo of a CRT tv screen the shutter speed has to match the scan rate. It used to be that 1/30th sec would give you a reasonably good image. Try changing the shutter speed.
Film: Leica M-4, Elan 7E, Rolleiflex 2.8f, Pentax 645 -- Digital: Canon Pro-1, EOS 5D
EOS Lenses: Sigma 24-70 f2.8 EX - Canon EF 17-40 f4.0L - Canon EF 24-105 f4.0L - Canon EF 35 f1.4L USM - Canon EF100-400 f4.5-5.6L IS USM - Canon EF100 f2.8 Macro - Other stuff: MR 14EX - 430EX - 580EXII - ST-E2 - TC1.4x - TC-80N3
KCMO Al is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #5
beanster
here we go, shutter 1/200. but thank you KCMO Al a shutter speed of 1/60 does give me an image with correct color (taa ) :
Matt
Old 10th of November 2006 (Fri)   #6
TMR Design
TMR Design's Avatar
Interesting. There is no refresh rate to deal with so I would think it should be like taking a picture of an LCD display which is easy and comes out pretty good. I don't understand the plasma technology enough but it looks like there is something about the screen (plasma) that reflects the light differently.
Lover of manual focus Zeiss glass.
Gear List & Feedback
Please call me Robert or Rob, not TMR
My Online Portfolio
TMR Design is online now   Reply With Quote
Old 10th of November 2006 (Fri)   #7
surfologist
surfologist's Avatar
Sweet!!
My! Gear! Bag!
All of my money has gone to L!! LoL
surfologist is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #8
CyberDyneSystems
Admin - MOD OF STEEL...
CyberDyneSystems's Avatar
But, these are moving pictures so there is "redraw" which will pretty much behave like refresh rate to a certain extent as far as taking a photo is concerned (though they exist for totally different reasons)
A static image on an LCD screen on you laptop is not comparable, but a movie on that laptop would be,.. and the movies frame rate would come into effect.
CyberDyneSystems is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #9
deadpass
deadpass's Avatar
plasma screens still have the response rate which is similar to the refresh rate of a CRT
a camera
http://www.deadpass.com
deadpass is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #10
lostdoggy
King Duffus
lostdoggy's Avatar
Plasma=small little fluorescent bulbs linked together to form an image by igniting a charged gas to created plasma (hence the name plasma) that causes the phosphers to glow its respective color.
lostdoggy is offline   Reply With Quote
Old 10th of November 2006 (Fri)   #11
beanster
for what it's worth...@ 1/60 the colors come out fine, the faster the shutter the more the colors go. Could it be that the camera stops the plasma technolgy's "refresh" in action?
edit: like a less technical version of what lostdoggy said
Matt
Old 10th of November 2006 (Fri)   #12
lostdoggy
King Duffus
lostdoggy's Avatar
Back to Op's question.
P&S uses alot of noise reduction and sharpen and color&saturation boosting and DSLR uses moderate amount.
I think the noise reduction is smoothing out the oily swirls.
Old 10th of November 2006 (Fri)   #13
lostdoggy
King Duffus
lostdoggy's Avatar
Just curious, doesn't PAL and SECAM (I think) sync at 50hz w/ respective AC service. Here the TVs syc at 60hz.
I don't know much about HDTV but regular TV broadcast is interpolated and requires a full sec to fully draw the screen. So it would take 2 pass to fully draw one frame.
Old 10th of November 2006 (Fri)   #14
Wilt
Wilt's Avatar
lostdoggy, you're on the right trail but following the wrong scent!
US TV (and a few other countries, too) refreshes at 60Hz to do one pass, and it takes two passes (alternating odd lines, then even lines) in an interlaced display to make a single image. So 30 frames per second.
PAL and Secam TV refreshes at 50Hz to do one pass, and it takes two passes (alternating odd lines, then even lines) in an interlaced display to make a single image. So 25 frames per second.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wide screen monitor distorting Photos jungle Accessories & Storage 2 17th of March 2007 (Sat) 15:06
Green screen for team photos???? dragonfly5 Small Flash and Studio Lighting 1 23rd of January 2007 (Tue) 20:14
Photos Don't Match Monitor Screen Images colliewalker1 RAW, Post Processing and Printing 7 23rd of July 2005 (Sat) 10:48
Viewing 10D photos on television screen Rjohn518 Canon EOS Digital Cameras 4 24th of January 2004 (Sat) 18:31
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
