Reply
Thread Tools Display Modes
Old 24th of January 2004 (Sat)   #1
RhoXS
Default Nikon SB-12 or SB-15 Strobes with G3?
Does anyone have any experience using either the Nikon SB-12 (F3 compatible) or SB-15 (FG compatible) strobes with the G3? Both strobes meter TTL on their respective bodies.
I strongly suspect that they will not work with the G3 but I want to be sure before I spend almost $200 on a 420EX.
RhoXS is offline   Reply With Quote
Old 24th of January 2004 (Sat)   #2
nguyenn_99
Default
I tried to use my SB24 speedlight on a Kodak DCS620, from what I read and learned from another forum is that for TTL flash to work correctly, the sensor in the body reads the light that reflects of the film while the shutter is open. The CCD sensor wouldln't have the same reflectance compare to film, the TTL flash wouldn't work correctly. You would have to use it in "A" mode.
I tried my SB24 with the G5 in A mode. It will over expose and you will have to learn to adjust accordingly.
I would love to hear from other users who have tried this.
nguyenn_99 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Firing strobes from Rebel XTi + Good strobes. The Fox Small Flash and Studio Lighting 15 6th of July 2007 (Fri) 09:34
WTB: Canon 1DMKII (N), Nikon D200, Nikon D2XS keropipi Classifieds: Buy 1 21st of June 2007 (Thu) 13:13
Strobes - Is this all I will need? darkvibe Small Flash and Studio Lighting 6 22nd of March 2007 (Thu) 08:04
Strobes, who uses them? swatcop169 Weddings and Other Family Events 21 21st of October 2006 (Sat) 11:41
