Reply
Thread Tools Display Modes
Old 13th of November 2006 (Mon)   #1
45R
Default 28-135mm IS USM lens error 99 message
The Canon 28-135mm IS USM lens is giving my 30D the Err99 Message. This is the only lens I have that errors out my 30D.
The lens is 2 years old and has never been dropped, I have over 15K snaps through it. What does the Err99 message mean and what can I do to try and fix it without sending it in.
Thanks!
45R
Canon 7D, Canon 30D, Canon 580EX,28-135mm IS USM
50mm F1.8,15mm F2.8,18-55mm Kit lens
17-40L,70-200LF2.8 IS, 2X TC
45R is offline   Reply With Quote
Old 13th of November 2006 (Mon)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: 28-135mm IS USM lens error 99 message
Err99 is a general "Unknown or unexpected error occurred". Before sending ther lens in, try cleaning the contacts on both lens and camera, and see that none of the contacts are recessed. You want to be sure they're all making good contact with the body.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 13th of November 2006 (Mon)   #3
45R
I tried cleaning the lens contact today and installed the lens. It worked for 10 shots then I started getting the message again. The rest of my other lenses work perfect, even my Sigma fisheye. I'll try cleaning the contacts on the camera today also to see what happens. I'll advise this evening.
Old 14th of November 2006 (Tue)   #4
45R
Everything makes a solid click when I attach it. Cleaning the contacts on the camera and lens did not work. Any other suggestions before I have to send it back to Mack Camera for a tune up?
I'm trying to rule out the camera also.
Old 14th of November 2006 (Tue)   #5
wazmunstr
wazmunstr's Avatar
if you dont have any problems with other lenses on your camera, im sure its not the body. unfortunately you have have to send it in for service.
Stuff|Stuff|And More Stuff
Online Portfolio:http://www.usefilm.com/photographer/33147.html
wazmunstr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LENS Error Message - Canon Powershot Pro1 sfarson Canon G-series Digital Cameras 7 28th of June 2011 (Tue) 20:38
Lens error message G2 alieber Canon G-series Digital Cameras 3 13th of April 2007 (Fri) 21:08
New 20D, New Canon Lens,- got " Error 99 " message? lhurd Canon EOS Digital Cameras 7 15th of August 2005 (Mon) 21:21
Error message....IMAGEMAGICK ERROR. hullodare Version 1.0-1.5 discussion 2 13th of July 2005 (Wed) 21:51
Error-Message: c-tree(R) error #235 (uerr_cod=0)!!! JollyJoe RAW, Post Processing and Printing 6 3rd of October 2001 (Wed) 05:15
