Reply
Thread Tools Display Modes
Old 27th of January 2004 (Tue)   #1
cheekycj
Default software to run batch images to autocorrect .. HELP
Anybody used some that they really like? Please give some feedback to help me choose.
Sp far I have looked at:
DCE: http://www.mediachance.com/dce/index.html
Qimage: http://www.ddisoftware.com/qimage/feature.htm
And also was told about Photoshop elements.
I am looking for a simple tool to quick fix (red-eye, color, etc etc) batch images. Any suggestions/advice would be appreciated.
I am a newbie so a tool with settings for G1 would be nice.
cheekycj is offline   Reply With Quote
Old 28th of January 2004 (Wed)   #2
FlyingPete
I am immune
FlyingPete's Avatar
Default
Check out NeatImage Pro (www.neatimage.com), it is primarily for noise reduction, but I believe you can also run additional filters over the image, the Pro version has an unlimited batch capability, the most I have loaded at one time was 870 images!
Not sure about the redeye though, that sort of filter I would be wary of, as it has a high chance of screwing things up if not supervised.
FlyingPete is offline   Reply With Quote
Old 1st of February 2004 (Sun)   #3
cheekycj
Default just downloaded neatimage...
I downloaded NeatImage.. I will try it out. Are you happy with its default settings or did u really have to tweak it?
CJ
Old 4th of February 2004 (Wed)   #4
pradeep1
pradeep1's Avatar
Default
Paintshop Pro 8.1 has scripting for doing batch corrections, etc.
www.jasc.com
Pradeep Satyaprakash
Please view my portfolio.
pradeep1 is offline   Reply With Quote
Old 4th of February 2004 (Wed)   #5
phili1
Default
Qimage is primarly a printing program that can do some adjustments. It is not a replacement for an imaging program, but it is the best printing program I have had to date.
Which one depends on what you want to do and at what cost.
phili1 is offline   Reply With Quote
Old 4th of February 2004 (Wed)   #6
cheekycj
Default what I am looking for
To fix images for printing. I have downloaded Elements and PSP and have started to play around with those. Photoshop CS seems to be a bit out of my price range
Old 5th of February 2004 (Thu)   #7
phili1
Default
Those are good. You can always upgrade later.
Old 6th of February 2004 (Fri)   #8
4walls
4walls's Avatar
Default Re: just downloaded neatimage...
CJ
I usually turn the settings down a little, otherwise the results can look a little "plastic" on skin tones. There is a little preview function before the noise reduction process. You can drag your mouse over an area to preview the noise reduction on that area alone prior to processing the whole image.
4walls is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Free Batch Copyright Software OviV RAW, Post Processing and Printing 24 1st of March 2009 (Sun) 16:30
Batch Re Size Software weka2000 RAW, Post Processing and Printing 8 2nd of March 2006 (Thu) 21:18
Batch scanning software red_snapper RAW, Post Processing and Printing 6 24th of October 2004 (Sun) 19:41
Batch Processing Software Woodman7 Canon EOS Digital Cameras 5 25th of September 2003 (Thu) 16:59
LS D60 doesn't run in batch mode?? JC Barker Canon EOS Digital Cameras 6 7th of February 2003 (Fri) 12:09
