#1 |
this paper seems to only work with a jpeg file in canon easy- photo print. if i use ps cs and a tiff file i am not able to align the picture correctly to print within the boundaries of the perforated sheets because there is no setup for perforated paper. is there a fix? i am using a canon i9100 printer. thank you.
| sponsored links |
#2 |
The solution that occurs to me off the top of my head is thus:
1. Measure the dimensions of the paper (or glean them from the package!) 2. Measure the distance between the edge of the paper and the perforations (or do the math!) 3. Create a canvas in Photoshop with the actual dimensions of the whole paper. 4. Place your 4x6 on the canvas, ensuring the whitespace all about is equivalent to the margins you discovered in step 2. 5. Print using a custom paper size. It occurs to me as I type this out that maybe you want the image a touch bigger than 4x6 so that it bleeds over the perfs. |
#3 |
i tried that, it does not work. thanks anyway. you would think since canon sell 4x6 pro paper only preforated there would be a way to print tiff files on it. it's a waste but for now i will have to tear 4 sides off the paper.
| sponsored links |
#4 |
I tell you what, I will attempt to do this tomorrow and I will detail the exact steps I take.
FWIW I have a Canon S600 and two sheets of this lovely paper left. I've been trying to find it locally and I can not! Very frustrating. Maybe someone else will come up with an answer for you before that. I hope so. Ye Gods but my plate is full this weekend! |
#5 | |
Easy PhotoPrint only displays thumbnails of JPEG files, so this is what you can sellect. In photoshop (or most other programs for that matter) make sure that you have setup the i9000 before trying to print. This includes checking the "borderless printing" check box in the Printer Properties, Setup tab. I usually reduce the "overspray" from maximum to 1 notch from minimum so as to minimize the amount of ink sprayed into the printer vs. on the paper while still providing the full borderless printing. I just printed a true 4x6 borderless (no perfs and actually 4x6 size) print of a RAW file with canvas resized to 4x6 300dpi from Photoshop CS and it came out as expected...beautiful and borderless To use your oversized, perforated paper, you will need to setup a custom paper size in Photoshop, set to the actual size of the paper, including perf area. Then set a border smaller than the distance from page edge to perf and do NOT check the borderless print box, as you will not be borderless printing with the perf paper. In the future, get the true sized paper and print true borderless. The paper is usually a bit cheaper and it is much easier with better results (no perf fuzzies). |
#6 |
i have never seen canon pro paper that was not perforated in the 4x6 size.
#7 | |
1. http://www.bhphotovideo.com/bnh/cont...631&is=REG (perforated edges) 2. http://www.bhphotovideo.com/bnh/cont...433&is=REG (for "edge to edge" printing) I've never used the newer version (#2). If you have #1, then you have to follow the instructions on the package insert carefully which gives precise instructions for setting image size (4.31 X 6.31 inches) and custom paper size in the printer driver (4.67 X 8.5 inches). You can save these settings, but I found the effort exhausting! I use my printer for large prints. It's cheaper to print 4 x 6 at my local printing service ($0.29 to $0.39 per print - depending on which service I use). |
#8 |
I use Epson's 4x6 perforated photo paper and use Irfanview when printing. Irfanview's interface is excellent for choosing size related to paper used. I have absolutely no problems.
Give it a try. Irfanview is a free image program. BTW, great name you are sporting there. Conk is short for Conklin. Just a nickname though. |
#9 |
dear conk: could you please tell me where to find irfanview on the net to download. thank you.
#10 |
| Thread Tools | |
| Display Modes | |
| WTB - Canon Photo Paper Pro 8.5 X 11 | gattaca | Classifieds: Buy | 0 | 9th of March 2007 (Fri) 18:35 |
| source for BULK canon photo pro paper... | ldivinag | RAW, Post Processing and Printing | 3 | 20th of September 2005 (Tue) 17:16 |
| Kodak Ultima Picture Paper 4x6 or 4x6.5? | djdino | RAW, Post Processing and Printing | 6 | 18th of March 2005 (Fri) 15:55 |
| canon photo paper pro 8.5"x11" | RJCONKLIN | RAW, Post Processing and Printing | 2 | 8th of February 2004 (Sun) 14:35 |
