FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 30 Jan 2004 (Friday) 20:18
Prev/next
G3 Lens Stuck! Please help
cloudless
Joined Dec 2003
Hong Kong
Jan 30, 2004 20:18 |  #1
My G3 stopped working all the sudden yesterday. When I turn on the camera the lens refuses to extend, a few seconds later the camera turns itself off. Has anyone else here heard or experienced the same problem? I always keep my lens adapter tube and UV filter on, I have no idea how I could have damaged the lens.
I feel so empty without my G3!
my photoblog:
http://cloudless.net
jnjdad
Joined Dec 2003
Jan 30, 2004 20:53 |  #2
sounds like battery is dead
cloudless
Joined Dec 2003
Hong Kong
Jan 30, 2004 21:10 |  #3
Nope the battery is alright. I can use the camera in playback mode, and I have tried using another battery too. Before it turns itself off, I see the "LENS" error message displayed on the top LCD display.
my photoblog:
Riccardo
Joined Jan 2004
Jan 31, 2004 04:41 |  #4
It is obvious, but be sure that the lens is not obstructed, and that there is no obvious physical damage to any part of the camera.
Look at it with a magnifying glass.
Ciao
CRCs ­ Reality
Joined Jan 2004
Jan 31, 2004 10:47 |  #5
I dropped my G3 from about 3 feet, with the lens adapter tube on (a few months ago), and this is exactly how mine acted upon powering it up.
The threads the lens rotates out on had become jammed, and I couldn't un-jam them. I ended up sending it in to Canon for repair, and $160 later I had it back and as good as new (they even replaced the LCD while it was there).
I hope this isn't the fate of yours, but if it is, at least the problem can be fixed.
cloudless
Joined Dec 2003
Hong Kong
Feb 01, 2004 01:18 |  #6
I am going to take my G3 to Canon for repair too tomorrow. It is still under the warrantee period, so hopefully I won't have to pay for the repair. I never dropped my camera hit it against any hard surface, so I really don't understand how it is damaged.
my photoblog:
submannz
Joined Sep 2003
Feb 01, 2004 19:05 |  #7
Most likely one of those freek manufacturing faults in the lense barrel.
JonK
JonK's Avatar
Joined Feb 2004
PA USA
Feb 01, 2004 20:59 |  #8
Thats no good
7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
check my blog:
www.jonkensy.comexternal link
cloudless
Joined Dec 2003
Hong Kong
Feb 01, 2004 23:44 |  #9
Looks like I am not alone... I wonder if it is a common problem for the G-series cameras. Anyway, I will post an update when I get my G3 back from Canon.
my photoblog:
John_T
John_T's Avatar
Joined Jun 2003
Switzerland
Feb 02, 2004 01:36 |  #10
I have two G5s and have had no problems with either. The lens protraction and autofocus mechanisms are robust enough for most handling, but they are fine mechanics. Could be you inadvertantly did something you were unaware of during handling that got the mechanism out of whack, but it could also be a production fault.
You could very gently try to help the mechanism ratchet back in while turning the camera on. Take the lens cover off and gently grip the outer lens edge with your finger nails, pulling, twisting and rocking back and forth. It could also be that it is not the mechanics, but someting further inside in the electronics or motor.
I had something similar with a G2, don't know what the cause was, but after playing with it a bit it started working fine again and I never had another problem with it.
If gentle coaxing doesn't do anything, definitely bring it to Canon.
Canon : 5DIV : 5DS R : 5DIII : 7DII : 40 2.8 : 50 1.4 : 35L : 85L : 100L IS Macro : 135L : 16-35L II : 24-105L IS II : 70-200L II : 100-400L IS II : 1.4x & 2x TC III : 600EX-RT : 580EX : 430EX : G1XII : Markins Q10 & Q3T : Jobu Gimbal : Manfrotto Underware : etc...
KRDV
Joined Oct 2002
Feb 02, 2004 08:09 |  #11
Several months ago, I had (still have) the same problem with my G3. My lens was stuck completely and was giving me the lens error with several "beeps" then would shut down. I couldn't get the camera to work at all. I sent mine it to Canon warranty repair and they fixed it (pretty much) and turnaround time was excellent. Over the last two months I have had it back, three times I have had the same problem (lens error, beeps, shutdown) but I have switched it off several times and then magically it had worked OK. Then it may go several weeks without any hint of the problem. I am at the end of my warranty coverage. I think I am going to send it back b/c even now that it's rarely happening, it may become more of an issue in the future after the warranty expires.
Cloudless, I also responded to your post on DPReview where I had a similar post from a few months ago.
http://forums.dpreview​.com ...orum=1010&message=6​481122external link (hope that link works.)
mookiemeister
Joined Jan 2004
Feb 02, 2004 08:59 |  #12
All this talk about defective lens on Canon G series makes me a bit apprehensive about my G3. For those people who have problems with their lens, do you use lens cap? I use lens cap and I don't manually remove lens cap. Instead I let the lens push the lens cap out when I turn on the camera. I'm not sure if this could cause problem with the motor not having enough juice to push the lens cap so eventually lens gets stuck. Anyone have thought on this?
KRDV
Joined Oct 2002
Feb 02, 2004 12:36 |  #13
mookie,
I wouldn't let this worry you too much. When it happened to me, I searched for threads on various sites and couldn't really find anything so it's NOT a common problem (IMO).
Second, after my warranty repair, the problem is so infrequent, it wouldn't be a major issue with me unless it gets worse as time goes on. Because I am still under warranty, I am sending it in. My guess is that many other cameras would have similar issues and overall, I think the G3/G3 is quite durable. That is consistent with what I have read.
Note: With the exception of probably 10 times, I always take the cap off manually so I don't think that the lens cap has any relation to it.
CRCs ­ Reality
Joined Jan 2004
Feb 02, 2004 16:39 |  #14
Mookie, I can't speak for others, but in my case it was definitely my own fault.
Really, it took a heck of a fall, I was surprised more wasn't broken. :)
Now, every time I put my camera down, I'm very careful (and a little slow-motion movie of the G3 tumbling off the counter replays in my head.. noooooo.....).
submannz
Joined Sep 2003
Feb 02, 2004 17:43 |  #15
Noooo, it is not at all a common problem this failure that was originally mentioned must have been a freek manufacturing fault.
As for the other ones mentioned was mainly due to a drop or hit to the camera, which would almost be expected from any camera
4,899 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00171 for 4 database queries.
PAGE COMPLETED IN 0.02s
Latest registered member is Lvlhr
1060 guests, 480 members online
