Reply
Thread Tools Display Modes
Old 22nd of March 2002 (Fri)   #1
TonyC
Default Card reader/writer.
Not realy for this forum I suppose but this is the one I read most.
I want to buy a CF card reader/writer, but I was told by the shop assistant that it was risky writing to one as it can wipe embedded information off the card that is necessary for its opperation. Is this correct or am I safe enough using one?.
Any advice appriciated.
Regards
Tony.
TonyC is offline   Reply With Quote
Old 22nd of March 2002 (Fri)   #2
gerry
Default Re: Card reader/writer.
i've used compact flash cards to download upgrades in firmware, and then loaded the firmware into cameras.
this involves writing to the card. i've never had any problems with imbedded information being wiped off.
and any time a card does give you a problem, you should be able to just pop it in the camera and format it.
gerry is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CF reader/writer? heksa Accessories & Storage 8 28th of April 2005 (Thu) 13:31
Using a card reader/writer & THM files Sky_&_Sea RAW, Post Processing and Printing 7 26th of April 2005 (Tue) 17:14
Does a CF card reader/writer enable uploading of avi files? tharmon Small Compact Digitals by Canon 2 14th of March 2005 (Mon) 11:50
Probs with card/reader writer cA70 Small Compact Digitals by Canon 4 2nd of October 2003 (Thu) 00:13
