Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > People
Reply
Thread Tools Display Modes
Old 27th of November 2006 (Mon)   #1
lilmill
lilmill's Avatar
Angry help with kids christmas pictures
I cannot get this to come out right.If I underexpose to get the lights then I get blur because I cannot get the kids to sit still, and when using my flash you can't see the lights. Maybe tomorrow i'll take one with the flash then try to a second quickly. Then use layer mask to show the lights in P.S.Any advice would be great.
7D,20D 3l's and a couple ef's
G10,D10, SD630
http://www.flickr.com/photos/lilmill/
lilmill is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #2
ashleymcnamara
ashleymcnamara's Avatar
Default Re: help with kids christmas pictures
The light pictures are hard...I know the vision you had because a recent client had the same one lol but I think it looks better to have lights behind the subject so that there aren't green cords everywhere. Know what I mean?
Cameras & Lenses
Canon 40D, Canon 30D, Canon EF 24-70 2.8L USM ,Canon 70-200 2.8L IS, Canon 50mm 1.4, Canon 15mm Fisheye Canon EF 50mm 1.8 ll, Canon EF-S 18-55
[BLOG] WWW.ASHLEYMCNAMARA.COM/ARTICLES
ashleymcnamara is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #3
DeltaWebb
DeltaWebb's Avatar
maybe try to expose for the lights and use your flash a stop down on the second curtain. Not sure that it will help but might be worth a shot.
Digital Rebel XT 350D, EF-S 18-55mm Kit Lens, Sigma 70-300mm f/4-5.6 APO DG Macro, 420 EX Speedlite, NEW BG-E3 Grip!!
After more than a year...Still learning to use it all
Gallery: http://www.photoedj.com
DeltaWebb is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #4
ABrownPhoto
aka SkWeEkiE
ABrownPhoto's Avatar
Hmmm interesting... I have no clue how to get the image you want, other than to underexpose the picture and then use some PP to brighten your two adorable subjects...
Hope you can figure it out and share the results!
He still has one more move.
I'm selling all my gear, CLICK HERE!!!
ABrownPhoto.com| Myspace | Gear List | Flickr
ABrownPhoto is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #5
hapa mamma
I am having the same problem. I have found that larger lights help, here is an example (no pp done). Now the problem is that although all of these lights were on, half of them appear to be off (left side). I think it's because they are LED lights. I am going to try with large regular lights next.
hapa mamma is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #6
lilmill
lilmill's Avatar
i'll try to pick some of the bigger lights up.
G10,D10, SD630
Old 27th of November 2006 (Mon)   #7
pristic
pristic's Avatar
I think the problem you have is that the flash is lighting the whole scene... subjects, background and the actual little lights.
What I would do is 2nd curtain synch and drag the shutter BUT you need alot more room between the subjects and the lights. (Think of a night time city shot with some people in the foreground) - I know this doesnt help with the lights that are ON the actual kids though.
This is interesting... It can be done though. (Ill ask around)
Peter.
God put me on earth to achieve a certain number of things... right now I am so far behind... I will never die!
Camera Gear
  • Canon AE1
  • Canon Speedlight 166A
  • Canon 350d
  • Canon Speedlight 430ex
  • 50mm f1.4 / 18 - 55 Kit / 70 - 300 Kit / 50mm f1.8 FD - Plus some Hoya filters
  • Home Made Digital Optical Slave Trigger (that works!)
  • Couple of cheap tripods
  • Bunch of bits and pieces to make life easier
pristic is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #8
JaertX
JaertX's Avatar
I took this one by placing the subject (my daughter) about two feet in front of the tree and feathering the light so that it wouldn't hit the tree and lights behind (much, anyway). The lighting is bright enough to expose her correctly, but then let the lights burn into the picture a bit
http://photography-on-the.net/forum/...0&d=1134793069
Jason - I use Canon and stuff
JaertX is offline   Reply With Quote
Old 27th of November 2006 (Mon)   #9
pagefile
pagefile's Avatar
I don't know if this will get you the look you want. But you can give it a try and make changes as you go.
Use you 50mm Set camera to M mode on the dial. Then set your shutter speed to 1/160 and have you apeture set at F/11 or f/5.6. Bounce your flash at about 45 degees. Set your White Balance to auto.
My Gear>>
"It is better to solve the right problem the wrong way than to solve the wrong problem the right way.”
Richard Wesley Hamming
pagefile is offline   Reply With Quote
Old 28th of November 2006 (Tue)   #10
SoccerRef
SoccerRef's Avatar
Not that I'm an expert, but it seems to me if you used a different color background, you'd have better luck too. The red background with the red sleeper makes distinction between the two difficult. Then add to that the fact that several of your lights are red, and the colors just don't have enough contrast to stand out one from the other.
I think if you used a dark background (black or dark green) you'd have better luck seeing the lights, as they would stand out from the background, not blend into it. (It would also set your daughter out a little bit). Since you have the kids actually holding the lights, I think you are going to have a tough time without a lot of contrast between the lights and the background.
Brighter lights wouldn't hurt either.
SoccerRef - PergerPhotography.com - SUPPORT POTN HERE
My Canon Gear -
7D, Gripped 40D, Gripped 20D, SD780IS, EFS 17-85 f/4.0-5.6 IS, EF 28-135 IS, 420EX
My Sigma Gear - 70-200 f2.8, 28-70mm f2.8 EX DG
Next in Line
- 5D, or Mark IIn
SoccerRef is offline   Reply With Quote
Old 28th of November 2006 (Tue)   #11
SuzyView
Ms Moderator and Grandma
SuzyView's Avatar
I did the light effect last year. The kids came out orange, but I didn't care. They were so cute. Have to set on longer exposure and they have to sit perfectly still. Hard to do with little ones. Keep the lights under the children mostly and let the lights glow a little. Matching jammies or holiday colors work best.
5D2 7D & G12, the new iPad, iPhone 5 , 5 L's & 2 Primes 23 bags - 4 Domke, 3 Lowepro, 1 Crumpler, 2 Tamrac, 5 Kata, 3 Thinktanks, 1 Pelican, 1 Tenba bag, 1 Epiphanie Paris & 2 Coach Handbag! And no excuses.
My children are the reason, but it's the passion that drives me to get the perfect image of everything.
My Gear and Wishes
SuzyView is offline   Reply With Quote
Old 28th of November 2006 (Tue)   #12
D. Craig Flory
Do this ... set up and photograph JUST the lights exposing properly for them. Then, add the kids and expose for them. In Photoshop .. use a layer mask and combine the two. This is the same way you would do sky scraper building to have detail in the building while also getting the lights on. You would create before dusk for detail. Then you would do some at & after dusk as the lights came on ... and then combine in Photshop.
D. Craig Flory PPA Certified, Cr.Photog.,
ASP // floryphotog@mindspring.com
D. Craig Flory is offline   Reply With Quote
Old 28th of November 2006 (Tue)   #13
rabidcow
rabidcow's Avatar
All you need to do is drag the shutter so that more ambient light flows into the lens. Dragging the shutter means allowing the shutter to stay open longer than you would normally. This works best in a dark room so turn off overhead lights. Try an aperture of f//11 and a shutter speed of 1/15. (ISO400) (on a tripod of course)
Your flash should freeze your subject, and the 1/15 shutter speed will allow your christmas lights to be seen.
Steven A. Pryor
Photo Manager, Prestige Portraits (Central Indiana)
Pixel peep or shoot...Pixel peep or shoot... or shoot...
Stuff
rabidcow is offline   Reply With Quote
Old 29th of November 2006 (Wed)   #14
pristic
pristic's Avatar
This is the way to get the lights, but you cant stop the motion blur of the children at 1/15 - unless maybe you use 2nd curtain synch and just a little pop of the flash maybe?
Peter.
Camera Gear
  • Canon AE1
  • Canon 350d
Old 29th of November 2006 (Wed)   #15
rabidcow
rabidcow's Avatar
Peter.
2nd curtain sync will do nothing for or against you in this situation. The key here is to have your flash overpower the ambient lighting (not the christmas lights, but the room lighting) and this alone will ensure that the flash freezes the kids, even if they are moving.
Steven A. Pryor
Stuff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Kids on Christmas shaneotool People 5 30th of December 2006 (Sat) 09:34
Christmas is for the kids! iplayazi People 7 27th of December 2006 (Wed) 08:09
Christmas Day and kids at play JMHPhotography People 14 3rd of January 2006 (Tue) 05:46
Christmas Photo -my kids TSEE People 0 1st of January 2006 (Sun) 08:44
A couple of Christmas kids mikesd People 8 21st of December 2004 (Tue) 18:11
