Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 1st of December 2006 (Fri)   #1
davvet2
davvet2's Avatar
Default Wein Hot Shoe To Hot Shoe Safe Sync (HSHSB) Question
I am thinking about buying a Wein safe sync and don't know which one to get.
My Rebel XTi has 4 pins and 1 larger button on the hotshoe, my Vivitar 283 Flash has one button in the center.
Which one do I need?
Thanks in advance --
Jim
davvet2 is offline   Reply With Quote
Old 1st of December 2006 (Fri)   #2
TMR Design
TMR Design's Avatar
Default Re: Wein Hot Shoe To Hot Shoe Safe Sync (HSHSB) Question
The extra pins on your XTi are for the Canon ETTL to work. Using a shoe cord and shoe with only a hot and ground will manually fire your flash but you lose ETTL. I just learned about this myself.
Please call me Robert or Rob, not TMR
Gear List & Feedback | My Online Portfolio
"Art is the elimination of the unnecessary." - Pablo Picasso
TMR Design is offline   Reply With Quote
Old 1st of December 2006 (Fri)   #3
davvet2
davvet2's Avatar
Thanks,
My plan was to use the Wein on the hotshoe of my camera, and the flash on top of the Wein.
The guy says the Wein doesn't have any buttons?
Old 1st of December 2006 (Fri)   #4
TMR Design
TMR Design's Avatar
I don't know anything about the particular device. Can you post a link to it?
Old 1st of December 2006 (Fri)   #5
davvet2
davvet2's Avatar
Robert,
I finally had sense enough to do a search on the site, and found out that I don't want to use the Wein adapter, as I would have to use the flash in manual. Thanks for trying to help me --
Jim
http://photography-on-the.net/forum/...d.php?t=127589
Old 1st of December 2006 (Fri)   #6
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
You can use the 283 in auto; just set the camera to manual or Av, using the aperture the 283's computer dial tells you to use for the approx. distance and ISO in use. And you want just a straight hot shoe Safe Sync. Doesn't need the extra pins, only the main contact.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 2nd of December 2006 (Sat)   #7
Titus213
Titus213's Avatar
My Wein SafeSync has a test button and a PC plug. I use it with my Sunpak 555 although I inderstand it might not be necessary with that flash.
Dave
Perspiring photographer.
Titus213 is offline   Reply With Quote
Old 2nd of December 2006 (Sat)   #8
davvet2
davvet2's Avatar
Jon,
Where do I find a straight hot shoe safe sync ?
This has all come about over using the Vivitar 283. I tested mine and it puts out 8 volts -- they say the max is 6 volts, and I don't want to ruin my new XTi.
Thanks.
Jim
Old 2nd of December 2006 (Sat)   #9
Titus213
Titus213's Avatar
http://www.bhphotovideo.com/bnh/cont...ughType=search
Dave
Old 2nd of December 2006 (Sat)   #10
davvet2
davvet2's Avatar
Thanks, Dave
Old 2nd of December 2006 (Sat)   #11
FlashZebra
This space available
FlashZebra's Avatar
My Sunpak 555 has a sync Voltage of only about 5 Volts, so a "Safe Sync" is not necessary for my particular unit.
There is additional info about other Sunpak 555 units on this site:
http://www.botzilla.com/photo/strobeVolts.html
But, you should check yours to be sure. All you need is a simple Volt meter and about 1 minute of work.
Enjoy! Lon
FlashZebra is offline   Reply With Quote
Old 2nd of December 2006 (Sat)   #12
davvet2
davvet2's Avatar
Enjoy! Lon
Lon,
I checked mine with a voltmeter in the DC position between the center post and grounding strip, it reads 8 volts on my Korea made Vivitar 283. That 8 volt reading has also been verified by the Botzilla website for other Vivitar 283 Korea made units.
No one has assured me that the 8 volts would work OK on my Rebel Xti without hurting my camera. I've read that the voltage shouldn't exceed 6 volts that's why I was looking into the Wein safe sync -- I may not need it if the 2 volt difference was OK.
Thanks,
Jim
Old 3rd of December 2006 (Sun)   #13
Titus213
Titus213's Avatar
Enjoy! Lon
Yup, check it to be sure. My 555 was giving me readings in the 7~8 volt range and since it was going on my 300D I opted to go the safe route. Given the number of shots I took before I got the 20D it probably was over kill.
Dave
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need help with my new WEIN hot shoe adapter Just Be Small Flash and Studio Lighting 9 24th of February 2007 (Sat) 01:52
Hot Shoe Adapter. Is it safe for the pins of the 580EX to touch the shoe? TMR Design Small Flash and Studio Lighting 15 15th of December 2006 (Fri) 17:16
Wein HS Hot Shoe Slave not working with 580 EX JX Small Flash and Studio Lighting 24 29th of October 2006 (Sun) 17:21
Pc sync hot shoe question rigorouslogik Small Flash and Studio Lighting 6 11th of October 2006 (Wed) 08:59
