#1 |
These shots were all taken with Canon D30, Canon 100-400 L, available light ISO 400.
All were processed with LS3.42 and maybe some additional tweaks. Then saved as level 8 jpegs. Please let me know what you think. Also first day out with Nixvue Digital Wallet - which was awesome! Thank you - Sean Bald Eagle 1 ![]() Bald Eagle 2 ![]() Polar Bear 1 ![]() Had a bad itch behind his ear! Polar Bear 2 ![]() Looks like he has a hangover - note the tongue hanging out stuck to the rock, a little hard to see - dark. Did not want to use flash. Polar Bear 3 ![]() Silverback Gorilla ![]() |
| sponsored links |
#2 |
The eagle pictures are excellent. The others are a bit flat looking. Maybe a lack of contrast? Looks like it was an overcast day so that probably had something to do with it. They are nice shots -- they just lack that "something." Just my $.02...
Todd
Todd Walker http://twalker294.posterous.com/ Canon 40D, 10D, G9, SX20IS, and SD500 |
#3 |
ISO 400 must mean a typical Ohio day. Not bad at all, concidering your light source challenge. This is definitely the reason for "flat" colors.
The question sometimes is, "This is all I have, do I shoot or come back later?". Glad you decided to shoot. Nice shots. What is happening on the muzzle with "Polar bear 3"? Did this happen post-processing or show up in the original? |
| sponsored links |
#4 |
Thanks for the comments - anyone's $.02 is appreciated.
Polar 3 muzzle - that was less than perfect composition on my part - there is another bear behind him and I just happen to catch the edge of the further bear around the muzzle of the subject - not too much I could do since it was a spontaneous moment - what a tongue! It was very overcast - no chance for any contrast as I did not want to use flash. Any other feedback is appreciated. Sean |
#5 |
SEAN
These are fine shots ... but I will put $20 on the table that says you will do 300% better the next time you go -- regardless of the weather. You may need a tripod (I am not sure). Be that as it may, I prefer your 1st shot, but would have liked to see 10 alternatives featuring more of the bird and more of bird and background. Of course I do not know your ZOO. Animals look a bit caged here -- or they may not be venturing away from the food door. Anyway, I want your next shots to transport me to Africa or to the North Pole. Something like that. HOWIE |
#6 |
Howie -
Thanks for the note. I believe you have laid out my challenge - transport you not to my zoo but to Africa. To provide more information I have attached more images to illustrate the barriers I need to overcome. Eagles in Nest - The viewing platform is inside the cage - but the very robust cage is easily seen in the background from any viewing angle. ![]() Eagle on ground - much better at seeing more of eagle, but not very dramatic on ground and still have fence in bg ![]() Baboons - very playful, more open environment, easier angle to exclude the 'man made' elements. ![]() Thoughts anyone?? Thanks again Sean |
#7 |
SEAN
Tough situation. While I do like the second set better, I can see that you were caught between a rock and a hard place ! Anyway, I should talk, I shot a few rolls at the Toronto Zoo years ago, but it seems to me that I did not do as well as you have here. Maybe all that anybody can do is look for a little more color. Thanks HOWIE |
#8 |
Considering the restriction placed upon you by the location, I liked your shots. It's obviously important to try and exclude any man-made structures from the frame, but this is not always the case. Sometimes you just have to improvise.
This is a shot from Sydney ZOO. The parrot was shot through a mesh cage. I moved as close to the mesh as I could (but it was still too far away, and diffraction robbed me of some contrast). A light tweak in Photoshop brought the contrast back, and here is the photo: ![]() D30, Canon EF 75-300mm lens at 300mm
• Wedding Photographer - Sydney and Wollongong • Borrowed Moment (blog) Life is uncertain. Eat dessert first. |
| Thread Tools | |
| Display Modes | |
| Cincinnati Zoo | Pandragon | Wildlife | 3 | 19th of July 2007 (Thu) 12:03 |
| Bright Peacock - Cincinnati Zoo | EveryMilesAMemory | Birds | 4 | 9th of July 2007 (Mon) 12:30 |
| Cincinnati Zoo with new 70-200 f/4L | parnola | Wildlife | 5 | 3rd of April 2006 (Mon) 10:13 |
| cincinnati zoo | wolverinesr1 | Wildlife | 2 | 20th of August 2005 (Sat) 08:31 |
| Cincinnati Zoo | trippinbillies40 | Wildlife | 1 | 1st of August 2005 (Mon) 19:19 |
