Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 3rd of December 2006 (Sun)   #1
mommytomjm
mommytomjm's Avatar
Default Ok, first question.....flash
My daughter's wheelchair has a canopy over it the majority of the time. I am finding her face in shadows all the time. I can lighten it up post picture, but I wonder if there is a setting that will help with this when actually taking the photo. (keep in mind I am totally new and don't understand f thingies, ISO, aperatures, etc.....so as much detail as possible would be good.)
Here's an indoor one.
Here's an outdoor one.
Thanks in advance.
Andrew, Bonny and MJ
See my pics at The Spot
Proud owner of a brand new Powershot S2 IS
mommytomjm is offline   Reply With Quote
Old 3rd of December 2006 (Sun)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: Ok, first question.....flash
Maybe get a white liner for the canopy? The usual procedure would be to set a reflector off to one side to bounce some of the light into her face. Rather awkward unless you've got someone who can stand around holding it. If you leave flash always on, you may get better results too, at the expense of some battery life (just carry two sets of spares rather than one, in that case).
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 4th of December 2006 (Mon)   #3
MaxZoom
MaxZoom's Avatar
Flash on all the time is a good starting point.
I don't understand why flash was not used for the indoor shot? Some people react badly to flash, would using the flash all the time be a problem?
So the flash does not become too dominant use fill-in flash setting - its called different things on different cameras.
For the indoor shot it would have filled in the shadow areas a fair amount. Outdoors and against the light you might not notice the effect much but will reduce the noise when you try to photoshop up the face in shadow.
Using the flash will drain the batteries quickly but you will get better shots.
Dont' worry about the flash being too harsh a light source, its better to have a harsh light than no light at all.
Max
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
MaxZoom is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flash Question (Sigma DG ST EF500 flash vs 430ex.) JaGWiRE Accessories & Storage 0 15th of September 2006 (Fri) 23:46
To Flash or not to Flash? That is the Question... onehottomatoe Small Flash and Studio Lighting 5 22nd of June 2006 (Thu) 12:34
To FLASH or Not to FLASH Tis the Question! Visuals General Photography Talk 0 26th of March 2006 (Sun) 13:25
The flash has me baffled (question about Canon flash options ShutteringFocus Canon EOS Digital Cameras 1 9th of November 2004 (Tue) 10:08
Another flash question Spinners Canon EOS Digital Cameras 3 18th of June 2003 (Wed) 19:50
