#1 |
Hi,
I've been a lurker here for some time now and this is my first post. I wanted to show you the two flash diffusers I made and get some feedback on the results. I usually shoot in full manual (flash and shutter speed) so I do not have examples of pictures in ETTL. The first one is based off the "Better Bounce Card" video and I made it out of fun foam I bought from Walmart. I picked up one sheet of white (bounce side) and a black sheet (the rear) then put it together with staples. The $2 for the materials allowed me to make 6. I love the results but I'm still learning what position and settings are best for each shot. ![]() My second device is made from a nylon shopping bag from Norstroms I found while cleaning my garage. The thought came into my head was theroy similar to the Fongsphere. This one requires stronger flash power for the same shot (f4.0 1/8 400iso shutter speed 1/200) vs. the fun foam bounce card (f4.0 1/16 200iso shutter speed 1/160). I love the results from this one too. Just set the flash power for distance and go. My only issue is that the colors seem a a tad flatter than the bounce card. ![]()
EOS Rebel XT, Sigma 15-30mm f/3.5-4.5, Nifty fifty, Canon 35-105 f/4.5-5.6, Canon EF 70-210mm f/3.5-4.5 USM, Sigma EF-500 super |
| sponsored links |
#2 |
The proof is in the pudding, shots look good, I've bounced with a simple piece of copy paper attached to the flash. If it works use it .
Just another shutterbug. I am not a photographer, I'm an image capture technician. Canon 40D - 70-200L f4, 28-135 IS, Nifty Fifty, 70-300 macro, 18-55 |
#3 |
Master Flasher
Funny thing...
No matter how many people post well-lit shots facilitated by cheap, home-made flash modifiers, there is at least one post per day asking "Should I get the Lightsphere II or the Sto-Fen?" Bouncing flash need not require expensive, bulky pieces of translucent plastic. And as you point out, successful lighting has more to do with experimenting and understanding than hardware. I'm not sure why you chose to attach the black foam to the white. It won't affect the function, but maybe you just like the looks better?
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
| sponsored links |
#4 |
Irrepressibly irresistibly Creamy
Location: You cannot know my location if you are busy measuring my speed
Good job! I've even used a bubble wrap sleeve in a pinch. worked nicely. . . plus the bubbles were fun to pop when I was done
#5 |
Thanks for the comments. I added the black backing on the foam bouncer because some folks who were standing behind me made a fuss about the light leaking through when it was just the white foam. I know it should let that bother me, but I tend to shoot at events where the booze are flowing and came close to a few incidents when using Sto-fen. shrug.
#6 |
"Cream of Corn" BurgerMeister
should I get the fongomnisrtofenlumiquest gold plated model?
#7 |
Master Flasher
Nah. Just bounce the flash off your forehead and fix the white balance in post.
#8 | |
POTN Strap with Accessories ![]() ========== IS is just a convenience. Bigger apperture is a necessity. gallery: http://www.flickr.com/photos/glennster/ |
#9 |
So I went by the art supply store today to buy another few sheets of fun foam. What I wanted to do is build a light bouncer similar to Lumquest's Pocket Bouncer for those times I won't have and low ceilings. Here's what I mustard up.
Test shots from 6 feet.
#10 | |
we over look the simplest things
Now how do I glue two pieces of foam together. Darn where's that foam adhesive.
David 5D | (2) 550EX | 17-40L | 28-135 | 50/1.8 | 85/1.8 | 70-200L IS Sigma 18-125 | (4)AB B400 | Load of Pentax M42's |
#11 | |
"My dog ate my title"
One found sheet of paper (ok, it had "Reserved" printed on it ) plus a quick scrounge through lost & found for a scrunchie to hold it to the flash and I was set.EDIT: BTW - I did return the scrunchie when I was finished, but the paper was pretty much toast. |
#12 |
Actually that's one of the features of the ABBC. You can turn it around and it really softens the light on the subject. To me ... putting the black on the back of it defeats one of it's best features.
#13 |
i've used the Gary Fong LS, both clear and the cloudy version. I like it. and It worked great for me. I dont know why ppl dont like him, i guess because he's asian and has a non-asian wife?? lol. anyway, i recently created this for fun. i didnt do much testing on it yet. maybe you can do on your free time.
![]() once you understand how to use a flash, it doesnt matter what you use or dont use anymore. john
----------------------------------------- johnlo photography Brooklyn New York Wedding Photographer My Gear List - updated 9/1/2009 |
#14 |
"I'm not sure why you chose to attach the black foam to the white. It won't affect the function, but maybe you just like the looks better?"
Well it does look better (I did the same on mine), but it also knocks the light splash down which blows through the white to the rear which was catching me in the eye and also bothers others in the vicinity. |
#15 | |
| Thread Tools | |
| Display Modes | |
| DYI Light Box | gzamira | Small Flash and Studio Lighting | 6 | 7th of June 2007 (Thu) 13:09 |
| My turn to play with my DYI tent light | Cleo199 | Still Life, B/W & Experimental | 3 | 23rd of March 2007 (Fri) 19:00 |
| FLASH: "To bounce, not bounce or sto-fen" | Bohlen Photo | Weddings and Other Family Events | 7 | 8th of April 2006 (Sat) 02:28 |
| Omni-bounce vs. 2-way bounce | Willie | Small Flash and Studio Lighting | 7 | 17th of January 2006 (Tue) 00:13 |
| 580EX - To bounce or not to bounce? | whaycock | Small Flash and Studio Lighting | 6 | 13th of December 2005 (Tue) 19:14 |
