Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > The POTN Lounge
Reply
Thread Tools Display Modes
Old 16th of December 2006 (Sat)   #1
s_erez
Default Depth of field and aperture selection question.
Hi,
I am relatively new to digital photography and I have a question related to aperture selection.
I am familiar with the theory behind the depth of field, the larger the aperture the more of a shallow depth of field and vice verse.
This is very simple to understand, however my question is how do you know which aperture to use for a specific situation?
I know about the depth of field button on the camera, but I could never see what my picture will come out when I used it.
Any techniques or tricks I could learn and use?
Thanks,
Erez.
s_erez is offline   Reply With Quote
Old 16th of December 2006 (Sat)   #2
17-40F4L
17-40F4L's Avatar
Default Re: Depth of field and aperture selection question.
practice, experience
17-40F4L is offline   Reply With Quote
Old 16th of December 2006 (Sat)   #3
cdifoto
Don't get pissy with me
cdifoto's Avatar
Originally Posted by s_erez View Post
Hi,
Thanks,
Erez.
Just kinda guesstimate really. Shoot a lot of situations with various focal lengths and apertures and see what it gives you. After awhile it becomes second nature.
That said, sometimes you're stuck with an aperture you don't really want to use because of the extremely narrow depth of field but need to suck in all the light you can get...
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 16th of December 2006 (Sat)   #4
kevin_c
Typically...
For landscapes, or any shot you want everything (or nearly everything) to appear in-focus you need to select a small aperture (f/11 - f/16 for instance)
For portrait's or any shot you want to isolate the subject and 'blur' the background you would select a large (f/4 - f/1.2 aperture)
Of course this is all 'typical' situations - you may want to use limited DOF on a landscape for effect etc. and if taking a group shot at a party you would use a smaller aperture to ensure everyone is in focus...
It does all come down to experience really.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
kevin_c is offline   Reply With Quote
Old 16th of December 2006 (Sat)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
True. At a distance, DOF extends 1/3 toward you & 2/3 away from the point of focus. In very close-ups, DOF extends 1/2 toward you & 1/2 away from the point of focus.
So if you're 10 feet from a subject and have a DOF of 3 feet, then everything from a distance of 9 feet to 12 feet will be inside the DOF
You could actually focus just short of infinity & get more DOField toward you. It used to be easier when all lenses had focusing marks on them.
Or you could try DOF tables to get a better idea of what's happening:
Depth-of-field
See the DOF calculator at the bottom.
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
question! depth of field tckadventures Macro 3 8th of November 2005 (Tue) 03:02
Depth of field question? paule Canon EF and EF-S Lenses 11 22nd of March 2005 (Tue) 18:01
Depth of field question Tom Camilleri General Photography Talk 3 23rd of February 2005 (Wed) 13:41
Depth of field question... CHR4MSU Canon EOS Digital Cameras 5 17th of August 2003 (Sun) 16:20
Aperture and depth-of-field peabobb Small Compact Digitals by Canon 3 10th of April 2003 (Thu) 06:45
