Reply
Thread Tools Display Modes
Old 21st of December 2006 (Thu)   #1
klmigut
klmigut's Avatar
Default Battery Drain- G7
Just picked up the G7 to take on vacation as a good point and shoot. I found however that the battery drained so quick and I was always having to recharge. I have never had this problem with any other Canon camera (20D, or Elphs, etc). Is this rare or just a glitch with this camera?
Thanks,
Kim
Kim Migut
Indianapolis, IN
klmigut is offline   Reply With Quote
Old 21st of December 2006 (Thu)   #2
GNMink
GNMink's Avatar
Default Re: Battery Drain- G7
I'm averaging 240-260 shots on a charge, and mostly shoot indoors with flash. CIPA rating is 220 shots. I would strongly suggest getting a good aftermarket high capacity battery like one from sterlingtek, they have a 1500ma rating twice that of the factory OEM batteries (they last 2x longer) and are less expensive.
Your shooting style will affect the battery life, some things will drain the battery quick such as reviewing of photos and if your shooting in poor lighting using the flash at max.
Canon G7 & SD800 IS
GNMink is offline   Reply With Quote
Old 28th of December 2006 (Thu)   #3
klmigut
klmigut's Avatar
Thanks, I am getting no where near that many shots, I think I had maybe 40-50 and it was dead.
Kim Migut
Indianapolis, IN
Old 28th of December 2006 (Thu)   #4
GNMink
GNMink's Avatar
If thats all your getting from a fully charged battery then the battery must be defective or the camera
Canon G7 & SD800 IS
Old 28th of December 2006 (Thu)   #5
rowdyred94
rowdyred94's Avatar
Or you're using it with the viewfinder on high brightness, continuous focus, and every other gizmo available. Sometimes power management is the problem.
-Clint
..:: Canon EOS 30D :: Canon 18-135 IS & 50 f/1.4 & 70-200 f/4L :: SPEEDLITE 580EX & 430EX :: Kenko tubes :: PowerShot G3 ::..
rowdyred94 is offline   Reply With Quote
Old 2nd of January 2007 (Tue)   #6
klmigut
klmigut's Avatar
Thanks, I am goign to send it back for a replacement. It happened again over the weekend, and I was very cautious with the viewfinder being off and such. Still only got about 40 shots in before it died.
Thanks!
Kim Migut
Indianapolis, IN
Old 30th of March 2008 (Sun)   #7
utopian
Hi, I'm thinking of getting a sterilngtek for my G7 here: http://sterlingtek.com/canbeqba80.html
Is the non-canon battery safe to use and can the battery be charged with the original canon charger?
TIA
utopian is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Battery drain peacock Canon EOS Digital Cameras 14 26th of February 2006 (Sun) 09:57
on / off battery drain ? Blue Deuce Canon EOS Digital Cameras 9 16th of November 2005 (Wed) 12:56
IS - BATTERY DRAIN? Steve Parr Canon EF and EF-S Lenses 2 19th of April 2005 (Tue) 11:32
D 60 Battery Drain?? mpross Accessories & Storage 4 26th of October 2003 (Sun) 21:54
Battery drain - Microdrive ? petiot Accessories & Storage 6 26th of July 2002 (Fri) 11:57
