Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 23rd of December 2006 (Sat)   #1
sativo
Default Some practicle advice
I own a small ecommerce business that sells imported home decor. We have a semi-pro digital studio with a canon d60 and strobes.. and have been achieving decent simple shots with a grey background.
We now want to advance our shots to look more like www.redenvelope.com
Can anyone give me some practicle advice on how to:
A) Achieve the lighting they have
Is it all naturual light or are they using highly diffused strobes?
B) Achieve the right DOF
Is is possible to reduce my lens to f/2.8 with studio lights? I always seem to catch the shutter in my shot?
C) Anyway suggestions on setting up a nice set. I don't have the super sofisticated home setting that they or pottery barn use. Is there anyway to fake it and get some nice variety?
Thanks,
Sativo
sativo is offline   Reply With Quote
Old 23rd of December 2006 (Sat)   #2
amonline
amonline's Avatar
Default Re: Some practicle advice
A) Regarding their typical "product" shots, most (of the products you referenced) have a medium to large softbox at 45 camera left with a reflector to the right of the product. It also looks like they like to shoot with a SB at product left and a closer reflector or considerably lowered SB at 45 camera right. Most jewelry tends to be back lit by a soft box with a reflector in from of the object.
B) There are many choices when it comes to lenses. Although many will recommend something like a 100mm (which I have), I tend to like using my 50mm or even my 24-105mm. Basically, anything in the 24-70 range is a good prospect. Then you can just calculate your DOF with a DOF calculator to establish the best distance. I would suggest using a computer thether or remote when shooting lightbox type work.
C) Believe it or not, you can setup a killer home lightbox for mere dollars if you are shooting small items. My small DIY lightbox cost me $24 in parts from Home Depot - lights and all and is good for products up to 1sq ft. I could go larger with just some more PVC pipe. There are many online tutorials with ideas about how to build the one for your needs. Check Google.
aLan
5DII x2, 15FE, 24L, 35L, 50L, 85L, 100M, 70-200L
amonline is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need Advice Crimson Tide Canon EF and EF-S Lenses 9 17th of April 2007 (Tue) 11:35
Need Advice synthetik Small Flash and Studio Lighting 12 1st of December 2005 (Thu) 00:09
Need an advice Milda Canon G-series Digital Cameras 3 13th of October 2004 (Wed) 03:04
Advice, please. quickben Canon EOS Digital Cameras 12 13th of May 2004 (Thu) 16:50
Please advice on choosing camera and other advice anh.nguyen@aanntt.com Canon EOS Digital Cameras 11 11th of April 2003 (Fri) 20:23
