#1 |
Hi all,
I'd like to know how I can improve my portraits. In every picture I can see the reflection of my softbox and umbrella in the eyes. I position the softbox in a 45 degree angle. Do I have to lift it also? How can I reduce the reflections? Matt |
| sponsored links |
#2 |
Photoshop might be easiest. I have the most trouble with glasses. Without modeling lights, it's hard to determine in advance. At least with digital, I can see the results immediately. Film would be some trial and error.
Gear list "Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters. Beginner's guide to printing. The PoTN film thread. |
#3 | |
Do you have a sample image? Recently there were a few threads about having 2 catchlights and most people said they just remove the second one with Photoshop. I recently discovered that I could have just the one catchlight if I used a reflector as fill instead of another light. As far as reducing the overall effect or brightness of the catchlight, I haven't gotten that far so hopefully some of the other guys here can help with that.
Please call me Robert or Rob, not TMR Gear List & Feedback | My Online Portfolio "Art is the elimination of the unnecessary." - Pablo Picasso |
| sponsored links |
#4 |
i think its the reflection of softbox in the eyes the OP is asking about.. actually seeing the soft box or brella in the eye...lol like big square catchlights.. I would just use PS to fix it you could try moving the lights but then you would end up PS'ing the catchlights back in anyhow...No?
My Facebook, Friend me If you want!http://www.facebook.com/brokenfencephotography http://www.facebook.com/theanimalhaven?ref=ts |
#5 |
Funny you should mention umbrella catchlights. Since I started as a photographer, I've noticed that many portraits used in headshots and advertising still contain the umbrella-shaped catchlight. Take a look in the Gap windows if you are near one soon. Here in Manhattan, at least, they have this effect.
"I have discovered photography. Now I can kill myself. I have nothing else to learn." -Pablo Picasso XTi with BG-E3, 50mm 1.4, 24-70mm 2.8L, 16-35mm 2.8L, kit lens, Tamron 28-200 Aspherical LD, Speedlights 550EX and 430EX |
#6 |
So you just want to remove all catchlight reflection from the eyes? What if you used very soft sidelighting?
Perhaps side and/or backlighting and reflector(s).
#7 | |
And I do realize that a quick trip to Photoshop with a clone tool can remove (fix) catchlights but I would like to avod that step if possible.
#8 |
Thanks fot your comment,
I attached a picture with my catchlightproblem. I don't prefer PS but I assume I'll need it anyway. I'd like to know your reaction about the catchlight. Matt ![]() |
#9 |
Well I'm no expert and also learning about lighting so I can only volunteer opinion. I like the catchlights, however I'm not a big fam of seeing 2 in each eye. Recently I started playing with reflectors and found that by using a reflector I could eliminate the second catchlight. So initially I would try that. I like the larger catch light but to me they lok a bit too large. That is something I hav enot learned how to control so I can't help with that. I don't know if positioning and distance from subject will change the size of the catchlights but you can give it a try. I'm afraid that I don't know a way to light the shot correctly without having at least one catchlight, unless you completely lit it from the side and/or back and used reflectors but I'm not so sure that would work.
#10 |
To me, it looks like there is a double catchlight, one from your main and another from the secondary on camera right. Since the hair and shoulders of your subject are a little dark, you could probably solve two problems by moving the main light back a bit. you'd eliminate the double catchlight, and second, you'd more evenly expose the subject, (if that's what you want to go for).
#11 | |
#12 |
Hi all,
I was thinking about a solution. In orde to light both sides I need to use to lights. But maybe I should have moved my umbrella untill the catchlight falls together with the white area of the eye. Is that a solution for the umbrella catchlight? According to the big catchlight of the softbox. The distance between the boy was approximatly 1.5 meter (about 4 feet?). So, if I put the softbox a bit further I assume the catchlight will be smaller. The only thing is that I need to take into consideration the flash falloff... is this a good solution? Matt |
#13 |
Sir Chimp-a-lot
Matt,
Yes the mainlight is too close, hot right shoulder (his) and underexposed left. Hotspots on the face are really distracting too. As far as the double catchlight, you can eliminate it by either moving the fill-light more off to the side or by merging the main and fill lights so that they overlap. I suggest the first solution. Also, if you want a stronger lighting ratio and good catchlight you can try setting your mainlight way off to the side, then set your fill-light straight on (right next to you) and use it to bring the dark side up to where you want it. Doing so will give you a good straight-on single catchlight.
#14 |
if you look at an olan mills portrait , they all have 2 catch lights in the pictures, i never noticed until i started taking pictures and paying attention, most every day people really dont worry about them, imo yuou cant take all the catch lights out of the eyes, ive tried this and to me the person i just snapped look dead, i think the catch light adds life to the subject being photographed, just my opinion. so it really doesnt bother me, and i agree with the above comment about the gap, look at adds, magazines, anything really they all have catch lights.
BILL HOOPES www.jumpingthrewphoto.com 40D, Sigma 17-70, 50mm F1.4, Newton Bracket, 580ex |
#15 | |
Now, think about the angle made by these three points: the subject's eyes (which are basically spherical), the light, and your lens. With the main light overhead, the light hits the eyes coming more or less straight down and bounces off at a 90 degree angle, straight into the lens. A good way to picture this is to imagine you've dropped a tennis ball (light) onto the front of a basketball(the eyes). You can see how the tennis ball will bounce off at an angle. Stepping back from the balls metaphor (which sounds dirtier than it is), you can probably now see how the overhead light produces a catchlight if it's given the opportunity to bounce off the subject's eyes. And because light is not a tennis ball, it will radiate outwards over a wide angle when bounced off of a sphere. For this reason, any light source placed in front of your subject will most likely give his/her eyes a catchlight. So, by moving the main light back a bit, the subject's eyebrows or head will shield the eyes from the flash, and it won't bounce off the eyes and into the lens. You'll still get a catchlight from the other strobe you're using, but you'll eliminate the double catchlight effect. Give it a try.
| Thread Tools | |
| Display Modes | |
| Eyes drawn to eyes | tau175336 | People | 3 | 9th of May 2007 (Wed) 10:37 |
| Anyone tried the alen bees softbox yet? or recommend a good softbox? | bocaj | Small Flash and Studio Lighting | 1 | 7th of May 2007 (Mon) 19:38 |
| Marble like reflection in a person's eyes | Digivaler | General Photography Talk | 9 | 6th of March 2007 (Tue) 02:13 |
| LumiQuest softbox or mini softbox? | ghaleon109 | Small Flash and Studio Lighting | 6 | 7th of September 2005 (Wed) 19:23 |
| flash reflection in dogs eyes | jlambe | Small Compact Digitals by Canon | 3 | 23rd of January 2004 (Fri) 12:22 |
