Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > People
Reply
Thread Tools Display Modes
Old 26th of December 2006 (Tue)   #1
JeratBP
JeratBP's Avatar
Default At the Scope again
how about this one? did quite a bit in PS, including removing a building from the background. pic was taken at 10am in late Nov. i know i would have had better light even earlier in the day.
- Jeremy Bailey
w/30D and some L Glass, a 50mm, a 580EX II and Gary Fong Lightsphere
JeratBP is offline   Reply With Quote
Old 26th of December 2006 (Tue)   #2
hard12find
hard12find's Avatar
Default Re: At the Scope again
A reflector might have helped brighten her face....Jim
20D, 10D, Fuji S-20, Mamiya C220 medium format, Sekonic L-508 meter, 2 alien bee 800's, AB remotes, Sigma 500 HS flash, 70-200 F2.8 L, Sigma 24-70 F2.8 EX DG, lots of glass, lots of stuff,
hard12find is offline   Reply With Quote
Old 27th of December 2006 (Wed)   #3
JeratBP
JeratBP's Avatar
I had left the reflector at home since I didn't have anyone to hold it.....should've brought it and the tripod and braced it against that.
Any other advice? 60+ views and no other comments?
- Jeremy Bailey
Old 27th of December 2006 (Wed)   #4
jra
jra's Avatar
Your subject seems overpowered by the backlighting. A reflector, as mentioned above, or some fill flash may have helped.
Jason
www.secondglimpse.com
jra is offline   Reply With Quote
Old 27th of December 2006 (Wed)   #5
JHH Photgraphy
JHH Photgraphy's Avatar
Seems lighting on the face is the only issue I have. Ok, maybe that you came so close to the feet yet cut them off. The way the picture was taken makes you want to follow the lines of the extended leg but then hit a dead end right at the foot.
James
XTi, XT, EF 50mm f/1.8 II, EF 85mm f/1.8 USM, EF-S 18-55mm f/3.5-5.6 II, EF 24-70mm 2.8L USM, EF 28-105mm f/3.5-4.5 USM, EF 28-135mm f/3.5-5.6 IS USM, EF 70-200mm 2.8L IS USM, EF 70-300mm f/4-5.6 IS USM, EF 100-300mm f/4.5-5.6 USM, EF 100-400mm f/4.5-5.6L IS USM, EF1.4x ll, EF2x ll
JHH Photgraphy is offline   Reply With Quote
Old 27th of December 2006 (Wed)   #6
D. Craig Flory
Lighting aside ... the pose is lacking. Her right should is cut off partly as is her hand. It would have worked much better created from twice as far away. Keep in mind how I think ... I can always crop later but I can never move back once the image is created. Her legs are not posed in a very feminine way.
Ok, now on to lighting. Keep a light stand with you. You can clamp a reflector to it. I own lots of light stands, and clamps.
But, for this image, the ratio from highlights to blacks is way too broad. I would have created images of her in open shade given the time of day.
D. Craig Flory PPA Certified, Cr.Photog.,
ASP // floryphotog@mindspring.com
D. Craig Flory is offline   Reply With Quote
Old 27th of December 2006 (Wed)   #7
PIXI_666
PIXI_666's Avatar
Its a very flat image and the lighting, WB and exposure is way off...
PIXI_666 is offline   Reply With Quote
Old 27th of December 2006 (Wed)   #8
CarsRFun
sup local photog!!!!!!!
edit: i work on main st live in chesapeake.
40d.. 75-300mm, 18-55is, 50mm 1.8F, 28-135is
CarsRFun is offline   Reply With Quote
Old 27th of December 2006 (Wed)   #9
Tungsram
Tungsram's Avatar
Seems like it's lacking contrast. Maybe the levels are off.
Whatever. My Flickr
Tungsram is offline   Reply With Quote
Old 30th of December 2006 (Sat)   #10
JeratBP
JeratBP's Avatar
here's the original pic.....before some PS work of course.
- Jeremy Bailey
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
adaptor for scope willy b Canon EF and EF-S Lenses 6 15th of March 2007 (Thu) 15:13
fitting 30D on a scope mknabster Canon EF and EF-S Lenses 16 5th of January 2007 (Fri) 05:04
Spotting scope fireturk1 General Photography Talk 3 8th of February 2006 (Wed) 11:34
Scope for the Canon G3 angela_online Canon G-series Digital Cameras 10 3rd of March 2004 (Wed) 08:16
Spotting Scope with D30 ?? Jesskramer Canon EOS Digital Cameras 3 7th of December 2001 (Fri) 09:09
