#1 |
Hey guys i have never shot snow before and i was looking for some tips on it. I can see it being overexposed very easily. I am new to photography so any help will be appreciated. thanks.
Canon Digital Rebel XT (350D) Canon Rebel X (Film) Canon EF 17-40 f/4 L Tamron EFS 70-300mm/Macro www.adamtroyerphotography.com |
| sponsored links |
#2 |
Actually it will severly underexpose cause the camera will try and make the snow grey. I had this problem shooting in La Plagne, France. Most of the time on the first day I had to watch the histograms cause I was metering off the whole scene. I soon learnt on the second day that metering off the sky or spot metering off your focal point and then recomposing your frame or shot makes the snow white. If you do wanna meter off the whole scene when compensate by upping the exposure by a couple of stops and watch the histogram.
Gear | Surrey Wedding Photographer | Surrey Wedding Photographer Blog | London Architecture Photographer |
#3 |
Master Flasher
+2 EC will usually get you in the ballpark, depending on what else is in the scene. Try manual mode, using the camera's meter and adjusting to +2 while aiming at the snow. Chimp and check histogram to make sure you aren't creating blowouts.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
| sponsored links |
#4 |
If there are subjects make sure they are in vibrant colors. Otherwise the photos turn out pretty dull.
I agree with other posters about metering. 18% Gray Card could be useful too. |
#5 |
Sliced Bread
I over expose about 1 1/2 stops to start then adjust from there.
Canon 1D MKIV, 5D MKII, 16-35/2.8L II, 24-105/4L, 70-200/2.8L IS II, IS, 500/4 L IS II, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, & 2X MKIII, (2) 550EXs, ST-E2. Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880 |
#6 |
Thanks all!
#7 |
Master Flasher
I'm going to be a nitpicker for a moment.
I understand what you're saying, but your use of terminology, though common, is incorrect and possibly confusing. If you adjust EC to +1 1/2 or whatever when shooting snow (or a bridal gown or a polar bear), you aren't overexposing, you're compensating for a high luminance target. Hence the term exposure compensation. And if you don't compensate enough, the shot might still be underexposed.
#8 |
white balance is critical.
snow is rarely white making it very hard to fix in PP and keeping it real looking. most ppl over whiten snow in PP.
..... ΜΟΛΩΝ ΛΑΒΕ |
#9 |
www.16sth.com |
#10 |
Master Flasher
What color is it usually?
As for white balance, the camera will usually get very close with AWB if shooting a snowy scene in daylight. If it's sunny, the snow in a shaded area will look blue if you set your WB on a sunlit target. This is true of anything on a sunny day but more noticeable with snow. Shooting RAW or using a custom white balance is a good idea regardless of what you're shooting, but either method is especially easy with a snowy scene.
#11 |
gray, white, black, off white and blue + lighting color.
there are little to no pure tones in nature. adjusting it too white kills the dynamic range making it look unreal.
..... ΜΟΛΩΝ ΛΑΒΕ |
#12 |
you might want to consider a polarizer filter. if its sunny out, the snow will reflect the sunlight.
Canon 30D | 17-85mm EF-S with IS | 430EX Flash 100mm f/2.8 USM Macro | 50mm f/1.8 II | 18-55mm lens kit 70-200mm f/4 L brodiehenry.smugmug.com |
| Thread Tools | |
| Display Modes | |
| Engagement shoot - outside w/ snow | gwc1023 | Weddings and Other Family Events | 3 | 15th of February 2007 (Thu) 14:39 |
| Shoot in snow... | tjrenegade | Canon EOS Digital Cameras | 10 | 1st of January 2007 (Mon) 16:52 |
| Snow shoot! | Seanwins | People | 11 | 12th of December 2006 (Tue) 22:18 |
| Another Snow Shoot! | SmilesforLife | People | 3 | 18th of December 2005 (Sun) 20:39 |
| 2 added to snow shoot | SmilesforLife | People | 3 | 18th of December 2005 (Sun) 20:36 |
