Reply
Thread Tools Display Modes
Old 29th of December 2006 (Fri)   #1
ylnad123
Default Tilt shift lens
After reading a lot on google about the tilt shift lenses I am still confused on what it does. I take a lot of pictures of shopping centers and office building and am wondering if this will help me more then the 10-20 I already have. Does someone have a picture taken with a tilt shift and the same picture without?
ylnad123 is offline   Reply With Quote
Old 29th of December 2006 (Fri)   #2
Wilt
Wilt's Avatar
Default Re: Tilt shift lens
The practical applications...
A rise-fall shift allows you to keep the film plane (sensor) parallel to the wall of a building yet still be able to see the upper portions of a skyscraper in a photo, thereby avoiding the converging lines of the 'falling over' building photo.
A lateral shift allows you to virtually position yourself to take a photo, yet keep yourself out of view from the reflections seen in mirrors on the wall opposite.
Both of the above are beneficial for architectural photographs of interiors.
A tilt allows you to alter the plane of focus, so that you can accomplish deeper apparent DOF without the need for as small an aperture. This is of greatest benefit to the landscape photographer, since trying to do this in interiors will result in other parts of the scene visibly out of focus!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is online now   Reply With Quote
Old 29th of December 2006 (Fri)   #3
Jaetie
Jaetie's Avatar
maybe a little reading here may help, though i'm not sure if you've already read this.
http://www.the-digital-picture.com/R...ns-Review.aspx
gear | flickr
Jaetie is offline   Reply With Quote
Old 29th of December 2006 (Fri)   #4
ylnad123
I understand the definition and understand what it does. But I guess I just can not tell if it will actually help me in what I do. Shopping centers are not usually tall, they are mostly long and sometimes have 90 degree breaks in them. I am just wondering if it would help me get more of the shopping center in the picture.
Lets say a shopping center is shaped like an L. Right now I can get the long end of the shopping ceter and a small part of the short end if I were to stand at the top of the L. I am wondering if at that angle with a tilt shift lens would I be able to get the whole L?
Old 29th of December 2006 (Fri)   #5
coreypolis
User is banned from forums
coreypolis's Avatar
not really, but you can better control perspective so that it isn't as distorted and you can't keep focus over a whole section of the building. angle of view isn't really changed
think of food photography for a second, a real closeup shot of a piece of pie turned 45 degrees. because of the way its positioned and DOF, you can usually only get a very small area of it in focus. A T/S lens allows you to move the plane of focus so its parallel to the food, rather than perpendicular, so you can get the whole thing in focus.
coreypolis is offline   Reply With Quote
Old 29th of December 2006 (Fri)   #6
braduardo
braduardo's Avatar
Look about half way down on this page:
http://photography-on-the.net/forum/...=236222&page=2
That's one of the best examples I can give you (that was given to me). For the effect it would have for buildings, just imagine the image bigger...
----Brad----
www.nybergstudio.com --- www.nyberg.etsy.com
40D: EF-S 10-22mm f3.5-4.5 ---- EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
braduardo is offline   Reply With Quote
Old 29th of December 2006 (Fri)   #7
Wilt
Wilt's Avatar
What camera do you have? One problem with APS-C cameras is that you cannot get full benefit of the T+S lens...24mm TSE is like using only a 38mm TSE on full frame camera. A T&S does not increase your FOV...that is defined by your format size. It changes the apparent perspective.
You don't have to have a tall structure to benefit! I shot the interior of a private home with a high ceiling better with the shift lens than without. If you were shooting a 2 story open interior shopping mall, you could present the mall better in showing less of the floor and more of the upper level without the converging lines. Or a lateral shift might permit better composition than simply shifting the camera or angling it differently.
Old 29th of December 2006 (Fri)   #8
ylnad123
Ok thank you, that picture really helps. I guess I am just a visual learner. Thanks for all your help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Tilt Shift lens Katzer1 Canon EF and EF-S Lenses 8 27th of May 2007 (Sun) 12:10
What a tilt/shift lens should do is..... Buddy Thomason Canon EF and EF-S Lenses 3 31st of July 2006 (Mon) 10:25
Tilt Shift Lens questions... Ken Fong Canon EF and EF-S Lenses 12 24th of July 2006 (Mon) 16:37
Tilt-shift lens Reed Goodwin Canon EF and EF-S Lenses 5 13th of July 2006 (Thu) 22:32
tilt shift lens bolantej Canon EF and EF-S Lenses 12 17th of June 2005 (Fri) 12:13
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
