Reply
Thread Tools Display Modes
Old 4th of January 2007 (Thu)   #1
TornadoFarm
Default Is my copy sharp?
I went out to shoot with my 17-40 on my Rebel XT (time is very limited these days), and it seems to be soft on the left side, but not on the right....... I can't figure out how to post a full resolution, as photobucket only allows me to post 800 x600. Anyways, I'm fairly new here, and have been lurking for some time, and just wondered if anyone could offer some help and/or suggestions?
This is unprocessed, i just converted to RAW then resized. (The other photos I shot were not sharp on the left side either) Thanks....
TornadoFarm is offline   Reply With Quote
Old 4th of January 2007 (Thu)   #2
LightRules
"flat out embarrassing"
LightRules's Avatar
Default Re: Is my copy sharp?
We really need to see a full-sized file of your images to see the border performance. If you are getting uneven side-to-side performance consistently, you've got a de-centering issue.
LightRules is offline   Reply With Quote
Old 4th of January 2007 (Thu)   #3
TornadoFarm
Thanks....... here is the full resolution
http://tornadolive.com/railroad3.jpg
Those trees on the far left seem way too soft.
Old 4th of January 2007 (Thu)   #4
Tsmith
Formerly known as Bluedog_XT
Tsmith's Avatar
Exposure Time = 1/15" at f/4 isn't a very good speed and aperture for determining sharpness.
Canon EOS 7D | Canon EF-S 10-22mm | Canon 17-40mm f/4L | Canon 24-105mm f/4L IS
Canon PowerShot S95
MY PBASE GALLERY
Tsmith is offline   Reply With Quote
Old 4th of January 2007 (Thu)   #5
TornadoFarm
yeah it was handheld.....but still, would it affect the left side and not the right? I'm a beginner here, so sorry for the questions.
Old 4th of January 2007 (Thu)   #6
LightRules
LightRules's Avatar
The bottom line here is that it's hard to say from this one image. You need to look for consistent results of this uneven performance. Take some more shots, especially where you have a nice and flat plane of focus, shots with higher shutter speeds. Just report back after you've viewed more images that would make you sure you've got an issue.
Old 4th of January 2007 (Thu)   #7
TornadoFarm
Ok, will do, thank you for your help.
Old 4th of January 2007 (Thu)   #8
Tsmith
Tsmith's Avatar
Do not get discouraged from this result as I think under the circumstances handheld especially it looks darn good. If testing at f/4 your gonna need a faster shutter speed to control image shake and you can't really worry about the corners at a wide open aperture, more so center sharpness and I see that in your image above.
Around f/8 is where you need to be concerned about edge sharpness.
Canon PowerShot S95
MY PBASE GALLERY
Old 14th of March 2007 (Wed)   #9
joegolf68
The entire image looked soft to me.
Peace be upon you
joegolf68 is offline   Reply With Quote
Old 14th of March 2007 (Wed)   #10
DenZ
DenZ's Avatar
I think its soft due to shake, also, what focal length are you shooting at? I think the 17-40 (according to charts) is sharpest at 17mm. However, it should also be very sharp at 40mm.
Try shooting your 17-40mm lens box from about 8 feet away with a tripod on at f/4 with good lighting. Set focus to center point and focus on the large EF 17-40mm letters.
BLOG | Equipment | flickr | dentonzhou.com
DenZ is offline   Reply With Quote
Old 14th of March 2007 (Wed)   #11
cosworth
I'm comfortable with my masculinity
cosworth's Avatar
Don't forget that contrast is how your eye sees sharpness.
Pick and image with lots of nice contrasty action on it. Shooting a grey winter day with nothing in the shot won't tell you.
Go find some nice brick or bare concrete wall and get someone stand there with some colours on. Big smile. We'll see sharpness in the corners fall off, sharpenss in teh eyelashes etc.
Best way to test this lens is a sunny day. Tripod. Set the lens to 20mm. AV mode and f/8. Lowest ISO you can get. Set the timer to 10 seconds and shoot. That way you eliminate %99 of the guessing:
Camera shake (tripod, shutter speed)
Contrast (sunlight)
Settings (focal length rule etc)
Natural lens limitations. (this lens is bland at 40mm)
Until then... who knows.
jasonhollister.com
Think your camera is noisy at high ISO? Click here
People will always try to stop you doing the right thing if it is unconventional
cosworth is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Soft copy/Sharp copy. laidbackman Canon EF and EF-S Lenses 29 2nd of April 2007 (Mon) 16:33
WTB: (CAN) 50mm 1.4 -- sharp copy franklinn Classifieds: Buy 1 26th of January 2007 (Fri) 01:47
Is There A Sharp 24-70mmL Copy? rockerdude Canon EF and EF-S Lenses 25 10th of February 2006 (Fri) 16:10
