Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Still Life, B/W & Experimental
Reply
Thread Tools Display Modes
Old 11th of January 2007 (Thu)   #1
goatee
"nice but dim"
goatee's Avatar
Default Torch flame
This is the flame on a torch (the kind used for torchlit processions). Focussing was a bit of a challenge, but I'm pretty happy with this one. I tweaked levels to alter the black point for the background, and boosted the midtones for the torch itself a little. Other than that, I used lens blur on the edge of one bit of the flame, where there were lots of little jaggeds.
C&C please
D300, 50mm f/1.8, 18-70mm f/3.5-4.5, 70-300mm f/3.5-5.6 VR, SB800
flickr
goatee is offline   Reply With Quote
Old 11th of January 2007 (Thu)   #2
goatee
"nice but dim"
goatee's Avatar
Default Re: Torch flame
One by one! I can't cope with this many responses to answer.
flickr
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LED Torch IMARLOW Still Life, B/W & Experimental 0 6th of January 2007 (Sat) 17:31
Emperor's Torch. DaleP Wildlife 3 11th of October 2006 (Wed) 07:56
The Torch Sn@ve Critique Corner 10 22nd of May 2006 (Mon) 00:10
Passing The Torch Spiral Photo Still Life, B/W & Experimental 16 27th of February 2006 (Mon) 21:14
painting with torch help!! blacktears Canon EOS Digital Cameras 12 2nd of June 2004 (Wed) 13:04
