Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 12th of January 2007 (Fri)   #1
4mr4do4sho
Default Flash & Macrophotography
I bought my wife the 60mm EFS for starters for her interest in macrophotography. When she takes close up shots of flowers and uses flash some of the picutures still come out a little dark.
Will the built in flash be sufficient for her macro needs or should I purchase her an external flash like the 430EX or better?
If she will need an external flash, any recommendations?
Canon 5D MK II, Canon 5D, Canon XSI
70-200mm L 2.8 IS |24-70L 2.8|17-55mm 2.8 IS| |100mm 2.8 macro|85mm 1.8| 580 EX II x2| 430 EX II| etc....
4mr4do4sho is offline   Reply With Quote
Old 12th of January 2007 (Fri)   #2
Curtis N
Master Flasher
Curtis N's Avatar
Default Re: Flash & Macrophotography
Underexposure is a common complaint of Canon's flash system, and can usually be fixed with flash exposure compensation. She'll need to use one of the creative modes to adjust this.
Depending on how close the camera is to the subject, sometimes the lens can block the light from the built-in flash. An external flash unit offers much more flexibility in this regard.
Canon makes a couple of flash units designed specifically for macro work. The 430EX can be good too, depending on the kind of light you want.
You might want to ask this question in the macro section for more specific recommendations.
Chicago area POTN events
Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator
Curtis N is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flash & Macrophotography 4mr4do4sho Macro 17 15th of January 2007 (Mon) 14:04
Flash macrophotography and FEC settings LordV Macro 3 13th of October 2006 (Fri) 23:48
WTB Macrophotography: Learning from a Master cybercoyote Classifieds: Buy 0 19th of April 2006 (Wed) 21:52
Macrophotography Kelpie Canon EF and EF-S Lenses 43 9th of June 2005 (Thu) 19:57
10D in macrophotography Sendide Canon EOS Digital Cameras 9 24th of January 2004 (Sat) 16:40
