Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 13th of January 2007 (Sat)   #1
turbodude
turbodude's Avatar
Default FIlters? I need some help selecting.
I want to buy a good set of filters, cp, nd and grad nd, but i don;t want to buy a set for each one of my lenses. Do they sell ring adapters? If so what filters do you guys suggest. I am from film and i just use to use tiffen and hoya.
What size should i buy? 77mm? And then step them down with an adapter?
Thanks in advance
turbodude is offline   Reply With Quote
Old 13th of January 2007 (Sat)   #2
CoolToolGuy
Boosting Ruler Sales
CoolToolGuy's Avatar
Default Re: FIlters? I need some help selecting.
As far as the grad ND is concerned, I would not go too far with buying a 77mm and then using a step-up ring. To take it to the extreme, if you put the 77mm on a lens that takes a 58mm filter, you will use only the center portion of the filter - not the clear, and not the full ND.
Other than that, the philosophy would work, but you may find that you can't use your hood.
Have Fun,
Rick
My Gear list
CoolToolGuy is offline   Reply With Quote
Old 13th of January 2007 (Sat)   #3
turbodude
turbodude's Avatar
cool thanks!
Old 14th of January 2007 (Sun)   #4
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
For grads, a rectangular one in a filter holder like Cokin's or Lee's would be best; these also take adapter rings for various lens dimeters.
Whatever filter you get, make sure they're good multi-coated ones. I use B+W MRC mostly. Hoya's SHMC and better are also good as are Heliopan. Tiffen's less so. My grads are Singh Rays.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need help selecting next lens... Clueless163 Canon EF and EF-S Lenses 20 19th of February 2007 (Mon) 21:50
help selecting monopod yahoo Accessories & Storage 13 13th of September 2006 (Wed) 17:16
selecting the AF Point pacific General Photography Talk 8 6th of December 2005 (Tue) 03:48
Selecting backrounds mknabster RAW, Post Processing and Printing 5 26th of August 2005 (Fri) 13:39
Selecting tpinchback RAW, Post Processing and Printing 6 23rd of April 2004 (Fri) 11:01
