Thread started 14 Jan 2007 (Sunday) 00:04
Prev/next
How to resize dpi in photoshop???
AliciaDawn
AliciaDawn's Avatar
Malmstrom AirForce Base, Montana
Jan 14, 2007 00:04 |  #1
Today I purchased some sloppy borders and the instructions said to resize image to 300dpi before dropping and dragging the border. I know what dpi is (dots per inch)--- but how do I resize them with my photoshop CS2?
Thanks so much for your help!!! :)
CANON 20D
Canon 18-55mm
Canon 28-80mm
Canon 80-200mm
Tamron 70-300mm 4-5.6LD.
blackshadow
Mr T. from the A team
blackshadow's Avatar
Melbourne, VIC Australia
Jan 14, 2007 00:11 |  #2
Open the image in photoshop then go to Image Size under the Image menu (Alt + Ctrl + I) and change the resolution - pixels/inch is the same as dots per inch.
Black Shadow Photographyexternal link
Facebookexternal link Flickrexternal link Twitterexternal link
Gear List Myspaceexternal link
AliciaDawn
AliciaDawn's Avatar
Jan 14, 2007 00:18 |  #3
Okay, so I need to resize my image to 300dpi is what the instructions are telling me- and this screen shot is telling me what the info is. What do I need to change to make it 300dpi? I am so confused! Sorry for being so dense!
CANON 20D
Canon 18-55mm
Canon 28-80mm
Canon 80-200mm
BradT0517
I almost caught fire
BradT0517's Avatar
Jan 14, 2007 00:21 |  #4
click in the box that says resolution = 72 and type 300 then click ok
My Websiteexternal link
AliciaDawn
AliciaDawn's Avatar
Jan 14, 2007 00:28 |  #5
BradT0517 wrote in post #2537507external link
Will this make the image larger or smaller by choosing this? How does this affect an image?
CANON 20D
Canon 18-55mm
Canon 28-80mm
Canon 80-200mm
blackshadow
Jan 14, 2007 00:32 |  #6
If you don't change the size the image will remain the same size dimensionally but have a whole lot more pixels.
AliciaDawn
AliciaDawn's Avatar
Jan 14, 2007 00:35 |  #7
So, exactly what is the benefit to doing this? I hate doing something I don't know WHY I am doing it! I am trying to figure this all out, but I do some much with Photoshop that I know how to do but not quite sure why I do it! lol
CANON 20D
Canon 18-55mm
Canon 28-80mm
Canon 80-200mm
blackshadow
Jan 14, 2007 00:40 |  #8
I'd imagine the suggested change to 300dpi is for when you are wanting to use the border on prints - 300dpi is a fairly standard resolution for printing photos.
AliciaDawn
AliciaDawn's Avatar
Jan 14, 2007 00:41 |  #9
blackshadow wrote in post #2537618external link
Cool- thanks so much for all of your help! Much appreciated! :)
CANON 20D
Canon 18-55mm
Canon 28-80mm
Canon 80-200mm
tzalman
Fatal attraction.
tzalman's Avatar
Gesher Haziv, Israel
Jan 14, 2007 01:42 |  #10
If you unclick the Resample Image box, the pixel dimensions of your print will remain unchanged and only the dpi tag will change.
OTOH, leaving the box selected and leaving the print dimensions at 32x48 inches will add so many new pixels that image quality will be seriously degraded (and file size will be huge).
Elie / אלי
AliciaDawn
AliciaDawn's Avatar
Jan 14, 2007 09:19 |  #11
tzalman wrote in post #2537823external link
Oh! Okay, thanks so much for letting me know that! :)
CANON 20D
Canon 18-55mm
Canon 28-80mm
Canon 80-200mm
EOS_JD
Lanarkshire, Scotland
Jan 14, 2007 16:42 |  #12
By the way it's not dpi (dots are what printers produce). It's pixels per inch because your images are made up of pixels (not dots).
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
EOS_JD
Jan 15, 2007 16:31 |  #13
There's an equation I use to work out the unknown variable.
P=Number of Pixels (along axis)
PS = Print size
R=Resolution (ppi)
P = PS x R
or
PS = P / R
or
R = P / PS
From this you can work out the number of pixels you need for any given print size and resolution.
If you don't change the number of pixels in your image (resample box unchecked) you will not change your actual image pixels in any way. If you increase the resolution you just cram the pixels into a smaller space so the print size falls as the resolution increases.
If however you resample you are either adding or deleting pixels from your image and the computer decides which pixels to add/subtract.
I try not to upsample too much.
All My Gear
Tomi ­ Hawk
Tomi Hawk's Avatar
Sin City, Vegas
Nov 17, 2007 18:35 as a reply to EOS_JD's post |  #14
Ok .. I don't wanna high-jack this thread, however, why start another on the same subject?
With the risk of sounding totally dumb .. here goes ..
I have an image that I switched to 300dpi in PS .. (I use PS 6)
In the *Image Size* box, this is what shows ..
Width: 600 pixels
Height: : 761 pixels
Document Size:
Width: 2 inches
Height: 2.537 inches
Resolution: 300 pixels/inch
My question ..
If the document size states 2x2.537 inches .. why oh why does the image print out at
nearly 6 1/4 x 8 inches?
I'm kina puzzled .. :oops:
tonylong
...winded
tonylong's Avatar
Gallery: 60 photos
Vancouver, WA USA
Nov 18, 2007 00:32 |  #15
I imagine you have a setting in your printer driver that is making an "automatic" adjustment to a resolution that corresponds to something lower than 600 ppi. Try stepping through all of your settings in the various Print options, including the preferences for your specific printer. Double check references to size and resolution. If you see something that might affect the outcome, try changing it and testing. . That, for now, is about all I can suggest.
If you've done all these things already, sorry, just trying to be helpful!
Tony
Tony Long Photos on PBaseexternal link
Wildlife project pics hereexternal link, Biking Photog shoots hereexternal link, "Suburbia" project hereexternal link! Mount St. Helens, Mount Hood pics hereexternal link
125,484 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00298 for 4 database queries.
PAGE COMPLETED IN 0.03s
Latest registered member is lilbill0
865 guests, 406 members online
