Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EOS Digital Cameras
Reply
Thread Tools Display Modes
Old 3rd of March 2004 (Wed)   #1
mikekiwi
Default Cosina 19-35 vs. Sigma 18-50
Currently I'm owning a Sigma 18-50 DC lens to go with my D60. Today I was offered to buy a used Cosina 19-35 lens (don't know the price yet). Does anybody has experience with both lenses? Will the Cosina be an upgrade to the Sigma (wich is not that bad, but does show some CA and barrel distortion). I know it is still not a 17-40L, but still saving money for that one
Is it wise to go for this lens or should I stay with the Sigma?
Thanks,
Michael
mikekiwi is offline   Reply With Quote
Old 3rd of March 2004 (Wed)   #2
RichardtheSane
RichardtheSane's Avatar
Default
Never had the Sigma, but I did have the cosina.
I hated the amount of post-processing I needed to get a sharp image.
I NEVER shot wide open. Below is a typical sample from this lens (sorry about filesize, didn't want to compress too much) shot with 10D at 1/100th sec @ f5.6 on a tripod.
First image is a 100% crop, second image is there to give an idea of distortion,
Finally at the bottom is a link to the image as it came out of the camera, but that is a full size large/fine jpeg at about 3Mb
http://www.richardlindley.co.uk/imag...fftop_0026.JPG
Hope this helps
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
RichardtheSane is offline   Reply With Quote
Old 3rd of March 2004 (Wed)   #3
Mark Kemp
Default
I have the Cosina too, mine is not as bad as Richard's samples, but it is not brillaint either.
I just bought the Canon 17-40 and that is much better, but of course it is 3 times the price!
Never tried the Sigma 18-50. The 15-30 has pretty good image quality, somewhere between the Canon and the Cosina, but it is large and I find the handling a bit awkward. Some Sigmas require you to pull the focus ring and switch the switch to go from manual to auto, which can be a pain. I am not sure if the 18-50 is like this or not.
I guess lenses are like a lot of things - you get what you pay for, but of course the last 10 percent of the quality costs most of the money.
The Cosina is a reasonable budget lens, I would expect the Sigma to be better but cost more and the Canon to be better still and even more expensive.
I guess it depends on how much you have to spend, how much you will use the lens and what kind of quality you are prepared to accept.
Mark Kemp is offline   Reply With Quote
Old 3rd of March 2004 (Wed)   #4
mikekiwi
Default
Thanks for the info and the sample picture (great Richard, just what I wanted to see). I've decided not to take the lens and continue using the Sigma until I find a lens which is really an upgrade...
Cheers,
Michael
Old 4th of March 2004 (Thu)   #5
RichardtheSane
Default
No problem. I think you have made a good choice.
Out of interest, how does your sigma compare?
Old 6th of March 2004 (Sat)   #6
mikekiwi
Default
Well Richard,
the Sigma lens performed at least as good as the Cosina for what I could see. The Cosina looked very soft to me on almost every picture I saw, while my Sigma sure is very soft wide-open at 50mm, but overall it's a pleasure to use. There is some barrel-distortion at 18mm which maybe more that at the Cosina (hard to compare as pictures did differ a lot).
The barrel distortion is relatively easy to decrease with Panotools in PS, after editing in PS, it's very acceptable.
Please note that I made a city-trip and shot a lot of pictures of buildings at 18mm, and those are the situations, the distortion is most visible.
In everyday snapshots etc. you can hardly notice it.
There were some complaints of heavy CA with the Sigma, but I can't find it, while my Oly C40 did show some CA on the same trip....
I think the Sigma is well worth it's money, in the future I'll certainly do an upgrade, but for now it's o.k. to use it...
Cheers,
Michael
Old 6th of March 2004 (Sat)   #7
RichardtheSane
Default
It certainly seems to me that you have the better lens.
I would definitly place the quality of any sigma I have owned over this.
Strangly though the cosina looked fine on slide film
I now use the 17-40L and that is a very good lens, and also a lot of lens for the money. When you are ready to upgrade that lens is well worth considering
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cosina 100mm 3.5 Macro.. Any good?? tokyopunk Canon EF and EF-S Lenses 3 15th of July 2007 (Sun) 23:24
Cosina 70-300mm Abercrombie Canon EF and EF-S Lenses 6 14th of June 2007 (Thu) 14:04
cosina 100mm macro willy b Canon EF and EF-S Lenses 6 23rd of March 2007 (Fri) 18:17
Cosina 100mm f/3.5 macro goatee Canon EF and EF-S Lenses 0 5th of December 2005 (Mon) 05:07
COSINA 100MM f3.5? paule Canon EF and EF-S Lenses 1 21st of March 2005 (Mon) 06:28
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
