Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 3rd of March 2004 (Wed)   #1
deoveer
Default Help with A70 wide converter
Greetings,
Two weeks ago I purchased A70 and liking it. Previously I had used Nikon 3100 and Fuji FinePix 310, but I like the flexibility of A70.
Anyway, I have ordered lens adapter and wide angle converter. I read through the A70 manual but it has very little information about use of the lenses.
I would like to know what kind of shooting mode I should use (or required to use) with the wide angle lense. Are there any limitations?
Can I still use Auto feature of the camera? How about Macro, Portrait, Landscape and other such shooting mode?
Any help will be appreciated.
Thanks,
deoveer is offline   Reply With Quote
Old 3rd of March 2004 (Wed)   #2
stopbath
Default
The wide angle adapter is used for any photo where you want a wider view than given by the zoom lens at it's widest zoom setting.
A telephoto and macro adapter are also available for those needs.
You can use any modes like Auto, Program, Landscape, Portrait... that you want.
The adapter will likely come with further information.
stopbath is offline   Reply With Quote
Old 7th of March 2004 (Sun)   #3
Don Schaeffer
Don Schaeffer's Avatar
Default Shooting Mode
I use a .6x wide angle supplement as my normal lens. It works at every setting. The flash causes a shadow so I remove the lens if using flash.
--Don
Don Schaeffer is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Wide converter WC-DC58N Autumn Canon G-series Digital Cameras 8 17th of March 2004 (Wed) 09:24
A70 Tele Converter Out of Stock yahya Small Compact Digitals by Canon 5 28th of July 2003 (Mon) 04:12
Cant get a Tiffen wide converter...what (and where) to get?? w302nv Canon G-series Digital Cameras 6 24th of June 2003 (Tue) 08:04
G3 Wide Converter Lens pbarbier Canon G-series Digital Cameras 1 5th of February 2003 (Wed) 20:58
