Reply
Thread Tools Display Modes
Old 20th of January 2007 (Sat)   #1
turbines
Default Canon TC-DC58A converter
Is there any reason to believe that this adapter shouldn't work well on cameras other than the PS Pro? Has anyone tried it with G6 or S2/S3?
turbines is offline   Reply With Quote
Old 20th of January 2007 (Sat)   #2
MaxZoom
MaxZoom's Avatar
Default Re: Canon TC-DC58A converter
I'm not an expert but I've read on other posts that the letter at the end of the part in this case 'A' indicates optical matching to a given camera type. Its the edge and corners of the image where quality may suffer if the lens is not a good match. Not an expert - remember!
Max
There's no such thing as a bad photo, just the wrong audience.
EQUIPMENT: Canon Powershot S3 IS, 2x Transcend 2GB x150 SD, 2x 4GB Class 4 Dane-Elec SDHC, LensMate 52mm Adapter Tube and lots of stuff to hang on it.
A couple of flashes and a couple of strobes. My other camera is a Sony DSC-P200.
MaxZoom is offline   Reply With Quote
Old 21st of January 2007 (Sun)   #3
turbines
How does one test for corner and edge sharpness?
Old 21st of January 2007 (Sun)   #4
rpolitsr
Moderator
rpolitsr's Avatar
Some years ago I used a chart similar to the one below to measure/calibrate resolution on professional broadcast TV cameras.
Things do not change too much on this. dpreview.com described its ‘new’ resolution chart on October 2005.
Good quality resolution charts are not cheap enough for a normal hobby budget though.
rafael
Canon powershot Pro1, EOS RebelXT, EF-S 18-55mm II, speedlite 420EX, basic filters set.
My photo galleries
"PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED."
rpolitsr is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pop-up flash on Canon Powershot S3 IS obscured by WC-DC58A wide converter lens dockerysean Small Compact Digitals by Canon 1 31st of December 2006 (Sun) 13:42
"The Gates", taken with Canon S3, Wide converter WC-DC58A and Cokin P grad filter svpworld Nature & Landscapes 1 25th of September 2006 (Mon) 15:51
Who has the Wide Converter WC-DC58A lens snowrdr Small Compact Digitals by Canon 3 12th of April 2006 (Wed) 21:52
Canon EF 75-300 + TC-DC58A Narniaman Canon EF and EF-S Lenses 7 3rd of April 2005 (Sun) 12:45
