Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 29th of January 2007 (Mon)   #1
boomer3297
Default printing with elements 3
I have a 10x14 file and everytime I try to print on 4x6 with tab the photo is off center.
Can anyone give me the proper workflow to have maximum control over the quality of the output? I'm used to using paintshop pro 8. It's alittle different.
Thanks for your help!
Mike
Canon XTI
Tamron 17-50, Canon 70-200mm f4 L, Sigma 10-20, Canon 50mm 1.8, Sigma 70-300 APO(for sale)
My Flickr: http://flickr.com/photos/boomer3297/
My Blog: www.mattafoto.wordpress.com
boomer3297 is offline   Reply With Quote
Old 29th of January 2007 (Mon)   #2
rw2
rw2's Avatar
Default Re: printing with elements 3
If I'm going to print a 4x6 I will crop the picture in elements 3 using the preset 4x6 setting. Then go to print. When you go to the page setup I use the 4x6 index card and not the 4 x 6 with tab. I print using a canon 8500. Once I am in that printers properties I need to set the type of paper I'm using and also the size(4x6). Once done I will usually undo crop before closing the picture in case I want to print a different size of the same picture later.
rw2 is offline   Reply With Quote
Old 30th of January 2007 (Tue)   #3
davidcrebelxt
davidcrebelxt's Avatar
Also, if you are printing borderless... you may need to check the print driver setting to adjust the amount of "overspray" --sorry, can't think of the right term
When I set mine to the lowest amount on my Canon printer, it would appear to print off-center... I just bumped that setting up until it was truly borderless.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/photos/dcrebelxt
davidcrebelxt is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Printing with PS Elements MVines RAW, Post Processing and Printing 2 25th of April 2006 (Tue) 23:32
Photoshop Elements printing problem Roy Gold RAW, Post Processing and Printing 5 24th of May 2005 (Tue) 13:01
Color spaces, printing, and PS Elements 3 Hellashot RAW, Post Processing and Printing 1 14th of December 2004 (Tue) 11:31
Printing across two pages Photoshop Elements scubi RAW, Post Processing and Printing 2 14th of January 2004 (Wed) 06:07
Printing with Photoshop Elements 2 mike oth Canon G-series Digital Cameras 1 3rd of December 2003 (Wed) 18:59
