Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 1st of February 2007 (Thu)   #1
mizuno
User is banned from forums
Default Lightroom: Exporting Files?
Is there any way to export files instead of printing them?
ie. I want to print some files at my lab, I've set them up in the Print tab with borders watermark etc, but it seems I can only print them on my printer?
Any way to export exactly what I'm looking at, inc dimensions to file?
mizuno is offline   Reply With Quote
Old 1st of February 2007 (Thu)   #2
dtplink
dtplink's Avatar
Default Re: Lightroom: Exporting Files?
Your answer in that case may only be to save it as a PDF with high quality images embedded. To make sure you get the best though there's no better way than to lay it out in InDesign or QuarkXPress.
Ron
dtplink is offline   Reply With Quote
Old 1st of February 2007 (Thu)   #3
mizuno
Might as well just do it in Photoshop as per normal if that's the case...
I hope Adobe add this functionality to version 1.0
Old 2nd of February 2007 (Fri)   #4
Packhorse-4
Packhorse-4's Avatar
In Light room 4.1 you should be able to go to the menu bar and select:
File: Export
You will get a window that will allow you to choose the export folder, change the file names, select JPEG, PSD, TIFF, DNG file types and select the Color Space sRBG, aRGB or ProPhoto RGB.
There are a few other options in there as well. Hope this helps.
John
My Photos | My Gear
Packhorse-4 is offline   Reply With Quote
Old 3rd of February 2007 (Sat)   #5
Tee Why
"Monkey's uncle"
Tee Why's Avatar
Library Module, on the left side should be an "export" button.
Gallery: http://tomyi.smugmug.com/
Tee Why is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lightroom - Exporting backup Troopa RAW, Post Processing and Printing 2 22nd of July 2007 (Sun) 14:03
Lightroom and exporting for online printing Sypher.mp3 RAW, Post Processing and Printing 4 23rd of May 2007 (Wed) 18:37
Exporting Slideshows from Lightroom TMR Design RAW, Post Processing and Printing 7 12th of May 2007 (Sat) 11:53
Exporting JPGs from Lightroom w/ ICC profiles? doubledragon RAW, Post Processing and Printing 4 1st of May 2007 (Tue) 08:03
lightroom exporting question islandphoto RAW, Post Processing and Printing 4 16th of April 2007 (Mon) 20:14
