#1 |
Can G7 create a still image from a movie frame?
If yes, what is the quality of image? Thanks. |
| sponsored links |
#2 | |
Extract image from movie is soft related, it is always possible if you have the correct soft. The canon soft that comes with G7 has that option, but I've never tried it. You will not get the same quality as for snapshot, as there are contradictorious parameters like: - high frame rate (better movie) = lower aperture time - fixed optical zoom (stable movie image) = less focus control etc etc You should use the correct mode for the correct objective.
Canon G7 + HQ-Tripod30 Casio Exilim |
#3 | |
I've read in Casio Exilim EX-Z750 review that: "... You can also create a still image from a movie frame using something that Casio calls Motion Print. In fact, you have two choices: you can just grab a single frame (which will be saved at 640 x 480) or you can create a nine-image collage of sorts which has one big image in front with eight other frame grabs behind it (see above). The collage is saved at the 1600 x 1200 resolution..." from http://www.dcresource.com/reviews/casio/exilim_z750-review/ Just I didn't understand well, camera can do this or software? |
| sponsored links |
#4 |
You can but the highest resolution of the file will be 1024 x 768. If the movie is shot in low light, the images will be soft and noisy. You can use the Image brwoser /Zoombroser to do this. Select the movie you want and display it in a separate window. Drag the play slider to find the frame you want and click on "save this Image". Good luck!
#5 | |
The nine frame pic you mentioned is just an extraction of frames from the movie pasted in a nice way to form a pic. As I said before, extracting frame from movie is soft related, there are lots of soft for that (search). Once you extracted the frame, you can create your big picture with nine, ten, N frames by pasting them. My point is, you are talking about the programe that comes with the camera but not the camera... there are free and powerful soft for that.
| Thread Tools | |
| Display Modes | |
| Question for 20D users. | gooble | Canon EOS Digital Cameras | 33 | 13th of March 2007 (Tue) 23:27 |
| Question for EF 70-200mm f/4 L users | OceanView | Canon EF and EF-S Lenses | 13 | 24th of June 2005 (Fri) 05:18 |
| Question for MKII users | Tapeman | Canon EOS Digital Cameras | 8 | 17th of March 2005 (Thu) 20:13 |
| Question for 1D users | Pekka | Canon EOS Digital Cameras | 1 | 9th of March 2003 (Sun) 11:56 |
| Question for G2 users | Rustle | General Photography Talk | 4 | 25th of October 2002 (Fri) 11:27 |
