Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 10th of February 2007 (Sat)   #1
AussieCat
Default External flash compared to internal. 400D. XTI.
i know this question might seem really naive...
i have yet to buy an external flash for my 400d.
i'll need it for night club / social events photography i'll be doing soon.
but, is it normal that when i use my built in flash on my 400d that often
there is like a buffer / waiting periois before i can take the next shot with the flash again?
is this normal to have a waiting period sometime of 1-6 seconds?
if so
does this mean i need to just get an external flash to eliminate thi issue?
of do u ofetn have to wait even with external flashes before the batter will reload again / recharge the falsh? if u know what i mean
AussieCat is offline   Reply With Quote
Old 10th of February 2007 (Sat)   #2
cdifoto
Don't get pissy with me
cdifoto's Avatar
Default Re: External flash compared to internal. 400D. XTI.
Flash needs to recycle. It's as simple as that. Some are faster than others, often depending how much of the total capacity has been used. In other words if a flash is rated to recycle in 6 seconds, if you only use half of it's power for a given shot, you can expect a 3 second recycle time.
Onboard flash isn't known for it's range or speed.
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid!
cdifoto is offline   Reply With Quote
Old 10th of February 2007 (Sat)   #3
AussieCat
does this mean
if its a worry
i need to get a good external flash?
Old 10th of February 2007 (Sat)   #4
cdifoto
cdifoto's Avatar
The best way I can sum it up is if you need a flash, external is the best way to go. There are still "delays" with recycling but they won't be as bad as with the onboard.
Old 10th of February 2007 (Sat)   #5
AussieCat
sweet
makes sense
Old 10th of February 2007 (Sat)   #6
Bodog
Bodog's Avatar
The built in is great for fill-in in a pinch, but if you intend to shot in an environment where you know you will need flash, then you gotta have a good external, no way around it.
JimE
Color? It's all relative...
Bodog is offline   Reply With Quote
Old 11th of February 2007 (Sun)   #7
Jon, The Elder
teaching fish to ride a bicycle
Jon, The Elder's Avatar
Aside from making a 'hot spot' in your image, the built in is only reaching out about 12' or so. An external will extend that quite a bit and, if diffused, will give you much better control of the light pattern.
A 40D, a 30D, some nice glass and a great Shooting Partner.
"...As in music, so in life."
Jon, The Elder is offline   Reply With Quote
Old 11th of February 2007 (Sun)   #8
chris clements
chris clements's Avatar
The pop-up flash is just for fill or emergency. Range, even coverage and recycling are poor; you sholdn't be relying on it.
Go get a 430 now.
chris clements is offline   Reply With Quote
Old 11th of February 2007 (Sun)   #9
rowdyred94
rowdyred94's Avatar
I have a 430 and just switched from alkalines to Energizer 2500 mAh rechargeables. I was shocked to find that there was no recharge delay. The red light never even flickered. I could cycle my G3 as fast as I wanted. Sweet!
-Clint
..:: Canon EOS 30D :: Canon 18-135 IS & 50 f/1.4 & 70-200 f/4L :: SPEEDLITE 580EX & 430EX :: Kenko tubes :: PowerShot G3 ::..
rowdyred94 is offline   Reply With Quote
Old 11th of February 2007 (Sun)   #10
Wilt
Wilt's Avatar
All flashes have to recycle. An external unit might NOT be faster on recycle than the on-board flash! The way to get fast recycle is to combine an external flash with an additional auxiliary battery pack which is designed to recycle the flash unit very quickly; an auxiliary battery pack might only offer more shots, without faster recycle (it depends on the auxiliary battery unit).
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 12th of February 2007 (Mon)   #11
AussieCat
i have the 400d
whats the full oficial tittle of this flahs
i have to get it
Old 12th of February 2007 (Mon)   #12
AussieCat
u mean a batter grip yeah?
Old 12th of February 2007 (Mon)   #13
Wilt
Wilt's Avatar
No, a battery grip powers the camera...I don't know if it affects the recycle time of the built-in flash or not.
I as referring to external battery packs, like the Quantum Turbo, which provide very fast charge times for flash units that are separate from the camera.
Old 15th of February 2007 (Thu)   #14
AussieCat
question to anyone
if i get an external flash
will this help with the recyle time of my external big flash??
Old 15th of February 2007 (Thu)   #15
Wilt
Wilt's Avatar
Originally Posted by AussiCat
if i get an external flash. will this help with the recyle time of my external big flash??
AussieCat,
Your question is confusing. You have a camera, you do not have an external flash (yet). I have already replied that an external flash unit may not necessarily be any better than the in-camera flash for the recycle time, unless you have an external battery like a Quantum Turbo. and I have already replied that a battery grip does not help with recycle, it simply provides more shots.
Please state what you are considering adding to your kit. And what is 'will this help'...what is the antecedent of 'this'...what are you referring to
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
LCD on 30D compared to 400D TMR Design Canon EOS Digital Cameras 5 7th of October 2006 (Sat) 15:27
350D-400D compared (What parameters can do) evandavies Canon EOS Digital Cameras 13 21st of September 2006 (Thu) 18:08
Q: Will the 20D internal flash trigger an external 420EX? JohnnyG Small Flash and Studio Lighting 3 17th of October 2005 (Mon) 03:41
Cascading Style Sheets - external vs internal Epicurean Version 1.0-1.5 discussion 4 13th of October 2005 (Thu) 12:35
External/Internal Flash Question ThomasL Canon G-series Digital Cameras 11 12th of May 2003 (Mon) 15:47
