Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 15th of February 2007 (Thu)   #1
moviemaker
moviemaker's Avatar
Default Bowens Travel Pak
Guys,
I have two strobes, which have the kettle lead (3 pin) connection at the rear. My strobes can be used as slaves, connected by sync cable , but at the moment, I have a wireless trigger plugged in the jack.
Now, I have been looking to get a travel battery pack, such as the bowens travel pack from warehouse express.
The battery has a multipin connecter, which is what the lead will also have. Now, I take it that the bowens strobes also have the multi pin connections.
Can you get adapters etc, that convert from the multipin adapter to the 3 pin input on the back of my strobes.
Bowens do a full kit, with the strobes, softboxes and the battery pack, but I don't wanty to double up on things I have already got.
Could some please assist or offer any advise in terms of whether there is an alternative to this batter pack, that will fit mine ?
Many thanks
moviemaker is offline   Reply With Quote
Old 15th of February 2007 (Thu)   #2
moviemaker
moviemaker's Avatar
Default Re: Bowens Travel Pak
sorry guys,
forgot to mention they are courtnays, old but do the job
Old 16th of February 2007 (Fri)   #3
moviemaker
moviemaker's Avatar
bump .
With soooo many pros on here someone should know. :0(
Old 16th of February 2007 (Fri)   #4
peacock
peacock's Avatar
I dont have any details i'm afraid , but I have heard of a battery pack by... Innovatronix
a google search should help find more info.
edit to say that i have no idea if they will work on your courtneys
Just started populating a site with snaps @
www.3cakes.co.uk
peacock is offline   Reply With Quote
Old 16th of February 2007 (Fri)   #5
TeeJay
TeeJay's Avatar
Sorry, only just seen your post.
No, the Travel Pak will only work with the Bowens kit. Each head has two separate sockets. One for mains power (kettle lead) and the other to take the special low-voltage lead that comes with the pack - so unless your heads also have the low-voltage circuitry built in, and the same wired D-type connector, they're not going to be any good to you.
You could have a look at the Focus-on-Imaging show at the NEC at the end of this month, there could be something suitable there.
TJ
1DsMkIII | 1DMkIIN | 20D + grip | 70-200 f/2.8L IS | 24-70 f/2.8L | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea
TeeJay is offline   Reply With Quote
Old 16th of February 2007 (Fri)   #6
moviemaker
moviemaker's Avatar
Hi Teejay,
Thanks for your info.
I'm affraid my lights only have the kettle lead type connectors.
I have received my trade tickets for Focus.
Thanks again
Old 16th of February 2007 (Fri)   #7
TeeJay
TeeJay's Avatar
Originally Posted by moviemaker View Post
...I have received my trade tickets for Focus....
Hmmm... sounds like spending some money is on the horizon!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
yet another diy --- tetra pak diffuser dk1027 Small Flash and Studio Lighting 1 6th of July 2007 (Fri) 17:15
BOWENS Esprit Gemini 750+750+Travel-Pak Kit mizuno Small Flash and Studio Lighting 0 6th of July 2007 (Fri) 01:04
Sunpak 5000af isnt working with my tr-pak II BrianCowen Small Flash and Studio Lighting 0 31st of August 2005 (Wed) 16:35
Elinchrom or Bowens krobert6 Small Flash and Studio Lighting 1 17th of May 2005 (Tue) 03:33
NEW Service Pak for 10D Highland Canon EOS Digital Cameras 9 1st of December 2003 (Mon) 08:24
