#1 |
I started playing with a S50 (first camera) and when I try taking a close-ups shots of a rose, it comes out blurry.
I've set Macro to see if the close-up would come out nice and crisp but no luck. Could someone teach me the basics on how to take close-ups photos? TIA> |
| sponsored links |
#2 |
Try using a Tripod. You may want to try shutter delay to minimize movement, also (with a tripod).
#3 |
Get yourself a G3 and then check out this method...
http://www.photography-on-the.net/fo...ht=super+macro |
| sponsored links |
#4 | |
#5 |
Lighting is also very important, particularly for taking macro shots indoors.
Your subjects need to be well lit for the camera to focus properly, so try lighting your subject with bright indirect light - I use an angle-poise lamp.
IXUS400 user |
#6 |
Focus is critical. Use the smallest possible aperture and a tripod or use a veryhigh speed exposure and focus very carefully. Depth of field will be narrow in macro.
#7 | |
#8 |
No, exactly the opposite. When you use a small aperature the interference effects from the edges of the light act as a lens like a pinhole camera. The pinhole camera lens improves the focus of the lens throughout the depth field. Pinhole cameras never have to be focussed because everything is equally sharp. Larger f-stop numbers signify smaller aperatures (like f8 is the smallest aperature on the A70. I think f3.5 is the biggest.
--Don |
#9 | |
#10 |
brace your arm on something steady and use the 2 sec timer, or if you have tripod use it. Heres a gallery of braceyourself-2sec method
#11 |
Also, the focusing mechanism on these cameras use a contrast detection system. So find something contrasty to put in your little focusing rectangle....like a shadowed part of the rose or the pistils or something like that. A nice vertical contrast edge will quickly lock focus.
You definitely want to make sure you are within the proper focus distance. Also, the focusing sensor is less sensitive to red than other colors, so remember that when photographing red roses or red Ferraris. You may want to use manual focus in that case. I hope this helps. |
#12 |
i know this might sound like a dumbass question, but how do i find out what my focal distance is for my cam? im using an ixus 430..
| Thread Tools | |
| Display Modes | |
| The 70-200 does close ups. | queenbee288 | Canon EF and EF-S Lenses | 9 | 8th of August 2006 (Tue) 18:54 |
| Excavator close-ups | Olli | Transportation | 6 | 13th of February 2006 (Mon) 11:38 |
| Two close-ups | Torquemada | Macro | 6 | 15th of August 2005 (Mon) 10:29 |
| Close ups | Fer | Wildlife | 0 | 23rd of March 2005 (Wed) 11:22 |
| Close Ups - How exactly? | Switch | Canon G-series Digital Cameras | 11 | 20th of June 2003 (Fri) 16:17 |
