#1 |
User is banned from forums
If you shoot in raw, am I correct that you are better off shooting at ISO 1600 and them increasing exposure by one stop in ACR or DPP than using ISO 3200? WellI have another question, I did a search on this and found every answer said:
"you get the same effect as ISO 3200 for RAW shots by shooting at ISO 1600 and underexposing by a stop" "you're best shooting at ISO 1600, underexpose it by one stop and then bring it back up in the RAW convesion" "ISO 3200 is just an in-camera software boost. You can do the same, often with slightly better results, by shooting at ISO 1600 with exposure compensation set to -1 and then use software on your computer to brighten it up" I don't understand this. Why would you underexpose ISO 1600 by one stop or 1EV? ISO 1600 is one stop lower than ISO 3200, if you throw in -1 exposure compensation you're now two stops underexposed compared to ISO 3200 and have to give it a two stop boost in ACR or DPP? What is the purpose of this? Wouldn't it make more sense to shoot at ISO 1600 and then only have to give it a 1EV boost in raw? Im clearly missing something here. |
| sponsored links |
#2 |
If you want to simulate the camera 3200 ISO speed, you would have to reset your exposure settings in each and every mode (M, Av, Tv, etc). Why not just set the camera to 3200 (H), and not mess with your exposure settings? That is why it is a custom function, it saves you work in setting/resetting exposure settings in all the modes you might shoot in for one session.
Again, it comes down to what you need to do to get your shot, some folks might like to not use the 3200 internal software function of the 30D, and just control every single aspect of the shot manually, while others want to keep some settings the same, and let the camera compensate for the 3200 setting. If you shoot in Raw, it shouldn't matter. If you underexpose 1600 at some set shutter speed, or use the 3200 at normal exposure at same shutter speed, you will be able to tweak both in the Raw converter to bump the exposure to your liking. Either way, you will have noise that has to be cleaned up with the noise tool of your choice. Just my opinion on all of this.
7D | 100L | 24-70L | 70-200L f2.8 IS | Σ 50-500 OS | Σ 50 1.4 | Tok 11-16 | 18-55 IS | 55-250 IS Past Equipment | My Gallery | My Mini-Reviews Resources For Sale: Focus Genie MicroAdjustment Chart | Gel Genie Flash Gel Holder | High ISO Denoiser Action |
#3 |
Not all bodies run up to 3200, so sometimes you have to deliberately under expose by a stop or more to get useable shutter speed. Then it gets messy as you try and recover it in pp and have to give it a rinse with noise ware.
| sponsored links |
#4 | |
#5 | |
#6 |
I think that you get less noise properly exposing at 3200 than increasing 1600 at -1 exposure to proper exposure.
I have tried it. Proper exposure is the best case always, with one caveat that you should always put getting the shot above settings, noise, etc..., when in doubt. |
#7 | |
Well said! I don't know how many blurry, sorry shots it took me to figure out that a noisy "good" shot is much better than a clean blurry shot. |
#8 | |
e-k |
#9 |
if you are constantly pushing 3200ISO (except for indoor sports, where that it a fact of life), you need faster lenses..
I don't hate macs or OSX, I hate people and statements that portray them as better than anything else. Macs are A solution, not THE solution. Get a good desktop i7 with Windows 7 and come tell me that sucks for photo or video editing. Gear List |
#10 |
Moderator
ISO 1600 at EC -1 (so a ISO 3200 exposure) is slightly better then ISOO 3200 with EC 0.
Have a look in this thread from post #14 on... It also offers the advantage it's easier to keep highlights from blowing out, since you are shooting at ISO 1600 instead of ISO 3200
"I think the idea of art kills creativity" - Douglas Adams Why Color Management. Color Problems? Click here. MySpace Get Colormanaged PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED.
#11 | |
#12 |
I don't lean towards it because I don't have the option on my 350D
If I was shooting JPEG I would say using ISO 3200 (in situations which demand it) would be pretty much a must. However, if you're shooting RAW you can simulate an ISO 3200 camera setting by pushing an ISO 1600 shot with near identical results (within a margin of error). Pushing an ISO 800 shot is close but there will be subtle differences. Below that I wouldn't bother. So why would you push an ISO 1600 shot? As others have already mentioned, 1. You don't have an ISO 3200 setting on your camera 2. It's a quick grab and you don't have time to change the ISO. 3. Like René pointed out, you can fiddle with the highlights. e-k |
#13 | ||
Master Flasher
My biggest hesitation with deliberately underexposing at ISO 1600 is being able to chimp and properly interpret the histogram to get the exposure 1 stop below optimum. I have a hard enough time getting it right to begin with!
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
| Thread Tools | |
| Display Modes | |
| Hockey and ISO 1600/3200 - what to expect? | dlpasco | Sports | 1 | 7th of January 2007 (Sun) 19:00 |
| ISO 3200 vs ISO 1600 pushed in Post | RichardtheSane | Canon EOS Digital Cameras | 12 | 21st of February 2006 (Tue) 04:31 |
| Forced to use ISO 1600/3200 (trip report) | Longwatcher | General Photography Talk | 3 | 8th of September 2005 (Thu) 02:02 |
| Request: 20D ISO 1600 & 3200 Portraits | jO3 | People | 13 | 25th of April 2005 (Mon) 09:32 |
