#1 |
When using my Canon A-1 film camera, I will normally set the camera on manual, set a shutter speed, and then meter various areas of the frame with the camera. This usually will give me a good idea of the proper aperture setting, especially for scenes with both bright and dark elements.
I have been unable to figure out how to do the same thing with the G-1. It appears that the best I can do is look at the LCD screen and change the speed and aperture settings until the image appears properly exposed. When taking pictures in bright light, it is a little difficult to properly judge the exposure from the screen. I'd appreciate any suggestions on how to use the G-1 to meter the exposure. |
| sponsored links |
#2 |
you could just switch to Tv, set a speed, and do your metering, then switch back to manual to apply the settings you determine.
#3 |
Not sure why Canon disconnected the metering in this situation but we are stuck with it! So you can take a meter reading in one of the other modes and then transpose it onto the manual settings or if you are like me use a hand held meter.
| sponsored links |
| Thread Tools | |
| Display Modes | |
| All this M setting talk...questions on exposure, metering, etc. | Watarski | General Photography Talk | 16 | 1st of June 2007 (Fri) 15:04 |
| manual metering question... | flipteg | Canon EOS Digital Cameras | 8 | 23rd of May 2007 (Wed) 21:26 |
| When to use manual metering? | steve-o UK | General Photography Talk | 9 | 19th of February 2007 (Mon) 19:05 |
| Metering in Manual | R Schade | RAW, Post Processing and Printing | 3 | 14th of December 2006 (Thu) 13:09 |
| Exposure metering setting | gramps | Canon EOS Digital Cameras | 21 | 12th of March 2006 (Sun) 21:34 |
