Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 1st of March 2007 (Thu)   #1
marksonthestreet
marksonthestreet's Avatar
Default ring flash question
I just received my ringflash and was testing it out, mind you I've never shot with any kind of flash and here's my query, why does this happen at some shutter and aperture settings.
http://i114.photobucket.com/albums/n...street/wtf.jpg
marksonthestreet is offline   Reply With Quote
Old 1st of March 2007 (Thu)   #2
Wilt
Wilt's Avatar
Default Re: ring flash question
If you specified what shutter speed you were using, we'd have a better clue. Without it, it is a guess. Perhaps too high a shutter speed, which means that a slit forms the opening of the shutter that moves across the sensor. The brief flash goes off while the slit is open over part of the sensor, but is already extinguishes before the other part of the sensor is exposed. OTOH the transition is normally more hard edged that the blurry edge of the example!
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 1st of March 2007 (Thu)   #3
awad
awad's Avatar
your shutter speed is faster than the sync speed of your camera. (usually 1/200 or 1/250th).
awad is offline   Reply With Quote
Old 1st of March 2007 (Thu)   #4
marksonthestreet
ok, yeah that makes sense, I'm self taught with everything so that makes sense, i was at a 1.4 aperture <-dumb and shutter was like 1200+ so yeah that makes sense, after i went to f/22 at 250 it went away, thanks guys...but now what will i learn in my photo classes next fall
Old 3rd of March 2007 (Sat)   #5
matt1987
you could try to have the flash release on the 2nd curtain..
// Cameras: EOS 5D, but I mostly use the Mamiya 6x7
// Website: www.sublimegraphic.com (now with a blog!)
matt1987 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RING FLASH Question from newbie JbarryD Small Flash and Studio Lighting 5 9th of July 2007 (Mon) 00:38
Ring flash Question The_Camera_Poser Small Flash and Studio Lighting 7 23rd of May 2007 (Wed) 04:04
Ring flash question. retro Small Flash and Studio Lighting 5 5th of March 2007 (Mon) 23:03
Which is better, Flash Ring or Ring Light? yamezbond Small Flash and Studio Lighting 1 25th of April 2006 (Tue) 19:36
Ring flash question Ross McT. Small Flash and Studio Lighting 1 10th of February 2006 (Fri) 18:43
