Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 2nd of March 2007 (Fri)   #1
dewitp
dewitp's Avatar
Default S3 IS with WC-DC58A, blurry edges
I'm getting blurry edges, mostly in the corners, using the wide angle canon lens. I do turn on the converter option in the menu. I zoom to the point where I can no longer see the black rim of the adapter lens.
What should I be doing to avoid this issue? Do I need to zoom more?
Here is an example
http://img383.imageshack.us/my.php?i...img1725zd0.jpg
dewitp is offline   Reply With Quote
Old 2nd of March 2007 (Fri)   #2
spur
spur's Avatar
Default Re: S3 IS with WC-DC58A, blurry edges
I don't understand why you zoom with a wide angle. Doesn't that defeat the pupose of using the wide angle in the first place?
spur is offline   Reply With Quote
Old 2nd of March 2007 (Fri)   #3
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Wide adapters almost inevitably have distortion at the edges.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 4th of March 2007 (Sun)   #4
dewitp
dewitp's Avatar
If you don't zoom a minor amount, the photo displays the black rim of the adapter lens. I bump it to about 1.5x zoom, just enough not to show the rim, as I didn't see the point in taking pictures with a black circle around it.
I expected some bending, but I did not expect such high distortion. I'll have to play around some more.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon TC-DC58A converter turbines Canon G-series Digital Cameras 3 21st of January 2007 (Sun) 10:38
Who has the Wide Converter WC-DC58A lens snowrdr Small Compact Digitals by Canon 3 12th of April 2006 (Wed) 21:52
Blurry edges with telephoto lens flounder81574 Small Compact Digitals by Canon 2 17th of January 2006 (Tue) 10:38
Canon EF 75-300 + TC-DC58A Narniaman Canon EF and EF-S Lenses 7 3rd of April 2005 (Sun) 12:45
Blurry edges on my S45 byrnefm Small Compact Digitals by Canon 0 14th of April 2003 (Mon) 11:04
