Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 4th of March 2007 (Sun)   #1
Ferco
Ferco's Avatar
Question Recommend a tri-pod?
Hi ok I've already got a good tripod; the Slik 500 or something... now the only problem is that it has that pole going up through the middle so that you can raise for extra length... but that means that I can't get those "ant eye" shots or the really low macro photos... The problem comes thought as I would love to be able to, if possible, to have my bigma mounted on it... which ways a fair bit... 1.842KG I believe...
So does anyone know of a tripod that will allow pretty much a ground level shot but also hold the bigma...?
Thanks for any help
Canon Gripped 350D & 40D
100mm 2.8 Macro
| Canon 18-200mm IS
Canon 430ex Flash |
Kenko 1.4x teleconvertor | Extension Tubes | Slik pro 500DX tripod
www.mincher.smugmug.com
Ferco is offline   Reply With Quote
Old 4th of March 2007 (Sun)   #2
MDJAK
...the definition of a noob
MDJAK's Avatar
Default Re: Recommend a tri-pod?
Not sure which Gitzo model it is (go to www.bhphoto.com) but there's at least one that will hold that which also has an off center column that bends every which way.
mark
MDJAK is offline   Reply With Quote
Old 4th of March 2007 (Sun)   #3
sm1rf
sm1rf's Avatar
try the Manfrotto 055 pro, the column comes out and mounts horizontally, also has a short centre column to mount at about 4" i think. 6KG loading also. the 055 regular doesn't have these features i think. Try amazon, i think a market place seller does it for about £90 in black.
"Skill in photography is acquired by practice and not purchase"
http://underwoodphotographic.zenfolio.com/
sm1rf is offline   Reply With Quote
Old 4th of March 2007 (Sun)   #4
pcasciola
POTN SHOPKEEPER
pcasciola's Avatar
I use a Gitzo Explorer G2220 which can adjust every which way with a rotating center column. You can put the column at just about any angle from straight up to almost straight down. I'm sure the Bigma would be no problem since I use my Sigma 500 f/4.5 on it which is a lot heavier.
Philip Casciola
Pro Camera Gear - POTN Shop
Canon 20D w/BG-E2 grip, 1D Mark I, 1D Mk III (Waiting List)
EF 50/1.8, EF 85/1.8, EF 300/4L IS, Sigma 500/4.5
EF-S 10-22, EF-S 18-55, Tamron 28-75/2.8, EF 70-200/2.8L IS
Sigma 1.4x & 2x, Tamron 1.4x, Gitzo 2220 Explorer, 322RC2 grip
pcasciola is offline   Reply With Quote
Old 4th of March 2007 (Sun)   #5
freaking102
A bunch of tripods have reversible columns. For instance, my G1257. I think any Gitzo or Gitzo knockoff with a rapid column allows reversible column.
freaking102 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A new tri pod for me Analogsound Accessories & Storage 4 29th of December 2006 (Fri) 10:15
Mono Pod or Tri-Pod vs IS picworx Canon EF and EF-S Lenses 6 22nd of March 2006 (Wed) 20:28
has anyone used this tri-pod ? tsw910 Accessories & Storage 24 3rd of January 2006 (Tue) 03:42
Need a tri pod mikeymike Accessories & Storage 17 28th of August 2005 (Sun) 02:32
Tri-Pod FramerPDX Canon EOS Digital Cameras 8 23rd of October 2003 (Thu) 11:55
