Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 5th of March 2007 (Mon)   #1
tomwilli
Default Why some viewers show image......
Why do some viewers show a photo as over sharpened and some viewers don't?
If I view a photo (jpg) that was modified/fixed in CS2 in the Bridge viewer, it looks OK. But if I view it in the DPP viewer it looks way over sharpened. I generally notice this with hair. Why is this?
Many Thanks,
Tom
Canon EOS 40D w/ Grip | Canon EF 50mm f/1.4 | Canon EF 85mm f/1.8 | Canon EF 24-70 f/2.8L | Canon EF 70-200 f/2.8L IS | Canon Speedlite 580EX w/ LSII | 2 Pocket Wizards | Bogen Manfrotto 3021BPRO | Bogen Manfrotto 488RC2 |
tomwilli is offline   Reply With Quote
Old 5th of March 2007 (Mon)   #2
Hellashot
User is banned from forums
Default Re: Why some viewers show image......
Are you viewing them both at 100%? If you are viewing a processed and sharpened image at say 25%, the quick resizing a program does may make it look worse than viewing at 100%. DPP may also be applying additional sharpnening, but that is unlikely.
Hellashot is offline   Reply With Quote
Old 5th of March 2007 (Mon)   #3
tomwilli
Well, I'm viewing them both at 100 %. I'm not doing any resizing, just opening the jpg with the mentioned viewers. I guess may concern is which viewer is accurate?
Old 5th of March 2007 (Mon)   #4
marksonthestreet
marksonthestreet's Avatar
I know enough to be dangerous but my hypothesis is that either the codec used in CS2 speaks a different language than DPP, or it's just the nature of Lossy images, if you open a jpeg and save even the smallest change it gets reconverted and detail is lost and artifacts appear and it gets worse with every generation, like a vhs tape. As far as accuracy I'd say go with Adobe, they are buying everything and everyone.
marksonthestreet is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Miss Image contest and car show Steezy303 Transportation 4 1st of July 2007 (Sun) 08:42
Submitting an image for a show toddb The Business of Photography 7 21st of February 2007 (Wed) 21:16
Editing Raw Image to Show Detail in White Fur colliewalker1 RAW, Post Processing and Printing 4 18th of February 2006 (Sat) 04:33
Looking for some advice from the UK viewers here!!! Kenski The POTN Lounge 47 25th of March 2005 (Fri) 11:28
Image Magnified on AV Show Andrew Canon G-series Digital Cameras 3 21st of August 2002 (Wed) 07:29
