Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 8th of March 2007 (Thu)   #1
bdj3
bdj3's Avatar
Default focus and the 50mm
I am having a problem when I shoot with the 50mm..it tends to make some of the picture oof. is there something I'm not doing? How do I guarantee the whole picture is in focus? example:
bdj3 is offline   Reply With Quote
Old 8th of March 2007 (Thu)   #2
ibdb
TD's worst nightmare!
ibdb's Avatar
Location: Puyallup -- Don't worry. Nobody else can pronounce it either.
Default Re: focus and the 50mm
If part of the shot is in focus, and another portion at a different distance from the camera is not, then you probably need to shoot with a smaller aperture (f/8, f/11, etc.) to increase your depth of field.
This shot was at f/3.5, which is going to give you a pretty shallow depth of field in many cases. Try searching the forums for "depth of field calculator." There are a variety of them to choose from. With one, you can put in your camera, lens, distance to your subject, and aperture and get a pretty good idea of what range of distances will be in focus for any given composition.
Another possible issue, and one that I don't have any personal experience with (I don't have a nifty 50), is that the nifty 50 has been said to hunt for focus in low light situations, which could also affect your outcome.
ibdb is offline   Reply With Quote
Old 8th of March 2007 (Thu)   #3
ibdb
ibdb's Avatar
Found a few more minutes and used Curt's Photography Calculator.
Assuming the subjects are 6 feet away (wild guess and just for an example), a 50mm at f/3.5 would have everything from 5.7 to 6.3 feet in focus -- meaning your total depth of field would be about 6 inches. Anything closer than 5.7 feet, or farther than 6.3 feet will start to be out of focus. Go to f/8, and you have 1.3 feet to work with; f/11 gives you 1.8 feet.
Old 9th of March 2007 (Fri)   #4
bdj3
bdj3's Avatar
thanks so much! big help!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
help on new 50mm 1.8 focus chart...... nodoubt Canon EF and EF-S Lenses 9 23rd of November 2006 (Thu) 01:55
50mm f/1.8 focus problem DeepSpring Canon EF and EF-S Lenses 9 9th of October 2006 (Mon) 07:24
EF 50mm f/1.8 II focus drumbum Canon EF and EF-S Lenses 9 5th of April 2006 (Wed) 23:22
50mm Front Focus? xmetal2001 Canon EF and EF-S Lenses 16 23rd of December 2005 (Fri) 22:28
Focus help: 50mm f1.4 Chazs Canon EF and EF-S Lenses 5 24th of June 2005 (Fri) 00:46
