Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 10th of March 2007 (Sat)   #1
sapearl
emailed Tim some prozac
sapearl's Avatar
Default RF Trigger for 5D Shutter Release?
After posting this in equipment, I thought perhaps it really belongs in weddings. Apologies to the mod up front if I guessed wrong. Does anybody use a radio controlled (RF) remote shutter release with their 5D?
I shoot weddings alone and will often have my second 5D tripod mounted in the balcony, with the telephoto, aimed down at the sanctuary. I'll be on the floor with my main camera covering the action there and go back and forth between the two during the ceremony. The exercise is great, but a little hectic and there's always the danger of missing a shot.
I've seen the following product at B&H, but don't really know much other than what's advertised:
http://www.bhphotovideo.com/bnh/cont...#goto_itemInfo
Looks pretty similar to a modified keyless auto remote. With something like this I could be near the B&G but periodically trigger the "remote" camera in the balcony. Anybody us a setup like this?
sapearl is offline   Reply With Quote
Old 10th of March 2007 (Sat)   #2
Hassan2285
Hassan2285's Avatar
Default Re: RF Trigger for 5D Shutter Release?
I would say it looks pretty practical, however I know you are able to do it, but how would you compose your shots since you will be using it while you are still on the floor getting closer shots?
If you can manage that, then I say by all means go for it.
5D
580EX
Canon 24-70mm L F2.8
Canon 50mm 1.8 MkII
Hoping to add more soon
Hassan2285 is offline   Reply With Quote
Old 10th of March 2007 (Sat)   #3
sapearl
sapearl's Avatar
Originally Posted by Hassan2285 View Post
........but how would you compose your shots since you will be using it while you are still on the floor getting closer shots?
Good question - I'd certainly be limited in what I could do, as I am now while it's on a tripod. Currently I'll spend some time in the balcony changing focal length a little, but the tripod normally stays in one spot. It would be pre-aimed and focused.
The advantage of an RF remote would be to get a few more shots that I might normally miss when I'm "downstairs." I'm just not sure if a want to spend $100 for some added convenience. But it's an intriguing concept.
Old 10th of March 2007 (Sat)   #4
Hassan2285
Hassan2285's Avatar
Good concept I agree, but the only problem I could see is that your camera on the tripod mis-focuses (not sure if its a word but thought I would use it), while you are assuming it is properly focused. Im sure you would make sure everything is all dandy, but this could eventually become more troublesome in my opinion.
Personally I would go with rather walking back and forth to make sure youre in control rather then getting the RF,
just my .02 cents
5D
580EX
Canon 50mm 1.8 MkII
Old 10th of March 2007 (Sat)   #5
cosworth
I'm comfortable with my masculinity
cosworth's Avatar
If you own a set of pocketwizards you can mod a $10 ebay Adidt remote to fire your 5D.
You add a mini plug (with soldering) to the remote. In the end it cost me about $20 in gas n' parts.
1000 foot range is nice.
jasonhollister.com
Think your camera is noisy at high ISO? Click here
People will always try to stop you doing the right thing if it is unconventional
cosworth is offline   Reply With Quote
Old 10th of March 2007 (Sat)   #6
sapearl
sapearl's Avatar
Excellent suggestion Cosworth - I've seen people do that a lot with success. Unfortunately I'm just not handy with electronics . I also don't own any pocket wizards - yet.
Old 10th of March 2007 (Sat)   #7
sapearl
sapearl's Avatar
just my .02 cents
I can see this easily happening - the "misfocus" situation as the bridal party move in and out of FOV. Well, I'm patiently thinking this through and in no rush to dispose of cash on only semi-productive "wedding tools." I got a little rebate money which has been giving me ideas .
I really don't mind walking back and forth - I was just trying to think outside the box a bit.
Old 10th of March 2007 (Sat)   #8
picturecrazy
soft-hearted weenie-boy
picturecrazy's Avatar
I have an ADIDT remote, but it CAME with the sub-mini plug on it already! So it plugs right into my pocketwizards and fires my 20/30D reliably. The 20D and 5D use the same 3 prong remote plug, doesn't it? No modifications.
And usually, I set up a remote camera prefocused and precomposed so focus shouldn't really be too much of an issue? I dunno, never has been for me.
picturecrazy is offline   Reply With Quote
Old 10th of March 2007 (Sat)   #9
sapearl
sapearl's Avatar
Hi Lloyd - interesting setup. I have the Canon Remote Switch RS-80N3 for my 5D
but no Pocket Wizard. I'm trying to visualize your arrangement which sounds like a possible good solution for me. I'd just have to purchase a pocket wizard?
Old 11th of March 2007 (Sun)   #10
picturecrazy
Unfortunately, you'd have to purchase TWO pocketwizards... one to trigger and one to receive. Or you could use a sekonic light meter with the radio module. This is what I like to use as my remote control...
Old 11th of March 2007 (Sun)   #11
sapearl
sapearl's Avatar
Thanks Lloyd - wasn't ready yet to run out and purchase 2 pocket wizards. They are fine products but I wasn't ready to make that kind of investment at this time. The Dot Line RF remote at only $99 through B&H doesn't look like too bad a deal.
Old 12th of March 2007 (Mon)   #12
CScottMcQueen
CScottMcQueen's Avatar
http://cgi.ebay.co.uk/Wireless-Remot...QQcmdZViewItem
Same thing but might be a bit cheaper for you sapearl
CC more than welcome !
1DMkIIn/350d/BG-E3 grip/580EX/ 420EX/ E1 Grip/17-35mm HSM/18-55mm/Nifty Fifty/ 24-70mm L/ 75-300mm/90mm Di Macro/MT-9170/P-Pod/CS2/ETC,ETC.
CScottMcQueen is offline   Reply With Quote
Old 12th of March 2007 (Mon)   #13
picturecrazy
yo Stuart. Definitely let me know how that goes. I'm curious to see how reliable it is.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
I pulled the trigger (shutter?) (400mm f5.6L prime) Technological Canon EF and EF-S Lenses 14 26th of April 2007 (Thu) 13:39
shutter release s3 is superjdf Small Compact Digitals by Canon 13 12th of April 2007 (Thu) 01:53
Radio Remote Trigger for 5D Shutter? sapearl Accessories & Storage 2 12th of March 2007 (Mon) 15:57
remote shutter trigger on S230 kingmoose Small Compact Digitals by Canon 1 29th of September 2003 (Mon) 06:06
